Old 03-05-11, 08:49 PM   #1
Default Scott SE
Hello,
Took a trip north with my Overdue wife, see if the roads up north would shake the baby out lol
While I was up there I picked up my new beauty!
Here is the name tag, It took two pictures, one shows it as a SR on as a SE, will have a closer look again, Also the serial number is very low at 25, which either makes it very early or a anomaly as most other are 3 figures.
It is also stamped into the top of the cylinder
SE19 is cast into the crank case
This one looks like it was fitted with a 3 leg spider bit this seems to have been destroyed!
The magneto and bracket, has been adapted including the impulse fitting.
Cheers Steve
Old 03-05-11, 08:51 PM   #2
On 2nd looks it is a SE, stamped into the name plate
one thing I cant believe the amount of compression! its going to take some swinging.
Can a admin please change the title. from SR to SE
Cheers Steve
Old 03-05-11, 08:58 PM   #3
antiBRIGGSANDSTRATTON
Lovely! a friend of mine has the first PA ever built
cheers
Fowler 1PA,Petter W1H,Stuart P4,Villiers WX11, Single flywheel Lister A, 1931 & 1929 Shafty D's,1929 Bruston D,Wolseley WD2,Superbloc 3hp,Conord F2,1943 Fairbanks ZD,Lister Butter Churn,Brackett pump,Maroilles butter churn, D & F twin pump
Old 03-05-11, 09:00 PM   #4
Took the pipe work off and gave it a quick degrease
Here you can see the throttle linkage is very similar to a Villiers WX11
Governor spring tension screw
As you can see this has been beaten on the end of the shaft
The magneto that is there is dead but check out the scorch marks
Cheers Steve
Old 03-05-11, 09:27 PM   #5
Just for comparison with the WX11
Scott
Villiers
Old 03-05-11, 09:44 PM   #6
Hi Steve,
Well, the good news is that you've got the oldest Scott SE type engine known to me. Serial number SE 25 would have been built in the early 1930's, possibly as early as 1930 or 1931. I first became aware of this engine in 1988 when it was located in the Plymouth area. I see it still carries the Wico A magneto that it had then, although the governor system now appears to be complete. The owner at the time reported that it had been found driving a water pump.
Old 03-05-11, 10:01 PM   #7
Cheers Phillip,
So I presume they started at 1?
Looks like it come from close to home then france :D
The magneto is brown bread, I can see where the impulse would help in starting, I can hardly turn it over compression its mega! makes a hell or a thump! I will be in contact with a friend Andrew for a more fitting magneto.
The internals feel ok will have a close look though, shame the spider has been smashed up. will see if I can get a flat pulley, and a starting handle :D
the pipe work and oilers will also be swapped out for a more eye pleasing arraignment
Cheers Steve
Old 03-05-11, 10:08 PM   #8
The one I had would start easily using a rope wrapped around the pulley, never had a starting handle for it.
Old 03-05-11, 10:13 PM   #9
Ok thanks for that info, would make more sense, will see what happens when it gets to it.
Thanks for the info Phillip im pleased as punch.
Cheers Steve
Old 03-05-11, 10:32 PM   #10
Thats a delightful little engine Steve, very nice!
Have fun with it, bet that will make a nice noise when up and running.
