Old 04-01-18, 10:56 AM   #51
danthetangye
danthetangye's Avatar
Originally Posted by David Day View Post
Morning Chaps,
The fuel line is in the need of replacement, not a big job but while im sorting that out I was wondering if I should fit a small inline fuel filter?
What are your thoughts?
Provided you have cleaned all the rust and crud out of the tank it shouldn't need it. Is there a gauze on the tap/tank fitting anyway?
danthetangye is offline   Reply With Quote
Old 04-01-18, 11:21 AM   #52
If your tank is fitted with Ewarts tap you can get new filters..
https://www.ebay.co.uk/itm/British-S...or-Ewarts-Taps
Old 04-01-18, 04:50 PM   #53
Morning Chaps,
I had one fitted to a C12 when I got it, I don't think it looks very good?, I will replace it with a straight pipe as the tap has a filter.
VilliersC12Filter by Robert Starr, on Flickr
Old 05-01-18, 10:30 AM   #54
Agreed! That just looks wrong.
Anyone know where to get the gauze filters that sit around the banjo bolt?
Old 05-01-18, 01:59 PM   #55
Villiers services have the correct one for the C12 (part No. V404) - link
Old 05-01-18, 05:43 PM   #56
Cheers Stuart. Have them bookmarked but didn't spot the filter.
Old 07-02-18, 06:21 PM   #57
minorman
minorman's Avatar
Well, mine is all back together at last and looking good ! One broken tappet / cam follower was the cause of it's initial failure and it took an awful lot of work to get at it. Villiers Spares supplied the part and now it is ready to go once I put fuel and oil in it. Before I do, anybody got any idea what spark plug should be fitted ? It came with an NKG resistive plug but the spark is weak with this. I tried an ordinary short reach non resistive plug from my Morris 8 and that gives a good spark but it's not the right one.
I'm going metric inch by inch !
minorman is offline   Reply With Quote
Old 07-02-18, 09:11 PM   #58
The handbook recommends a Champion N8 link to N8 equivalents I have a Champion N5C for my F15
Edit: found there's still a few NOS N8 about - link
Old 24-04-18, 01:44 PM   #59
David Day
Let There Be Light!!!!!
Huge Thanks to Dan for sorting out the replacement minigen
David Day is offline   Reply With Quote
Old 24-04-18, 07:08 PM   #60
biggusdannus
biggusdannus's Avatar
Wahey, glad you got it up and running. Nice one.
Cheers Dan
biggusdannus is offline   Reply With Quote
