Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Generators
Old 09-10-17, 09:20 PM   #51
You'd have to try quite hard to get a low enough body resistance to do yourself much damage with 25 Volts though Steve - perhaps stand in a bucket of brine and wear a tin hat!
Perfection is not necessary as long as you always get things right.
Old 09-10-17, 09:26 PM   #52
skankin_giant
skankin_giant's Avatar
Still don't fancy it after being on my knees on a damp field. Maybe I'm just a bit over cautious, but as I had access to rubber matting thought rude not to borrow a meter or 2...
The Wizard from The Lizard
WW1 ABC, Norman SC, Sattley TA, Scott SE, Stuart H1, R3 & WD, Teagle B2, Villiers WX11
skankin_giant is online now   Reply With Quote
Old 09-10-17, 09:42 PM   #53
Originally Posted by CSdiesel View Post
Neil . If you want load the you need the volts and amps to provide it . It will be worthwhile once fitted and to hear the twin growling under a useful load
I have a pump that would load most engines well enough, all that can do is give me a bath when it goes wrong. Lol
But I suspect that a 2kv generator is somewhere in my future
Wolseley WD 8, Stuart Turner P5, Maytag 92, Kubota KND3.
Hornet 6 is online now   Reply With Quote
Old 09-10-17, 09:48 PM   #54
CSdiesel
You can't have a chatter with a load of mates with a few beers in the light of a pump though
CSdiesel is offline   Reply With Quote
Old 09-10-17, 09:53 PM   #55
After a few beers you wouldn't be that bothered surely.
Lister M is online now   Reply With Quote
Old 09-10-17, 10:24 PM   #56
Ah, but you could use the pump to dispense the beer?
Old 09-10-17, 10:24 PM   #57
But will be ok to plug a 110 volt equipment into yeh ? is this what they call shared earth making it 55/55 ?
The transformers are normally centre tapped to earth so you only have a 55V potential on each leg for site safety.
Yes it will run 110V kit OK
Old 09-10-17, 11:01 PM   #58
After a few beers I really don't care what running, or not
Ask Phill
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
