Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Specific Forum Sections > Lister D & F
Old 08-06-18, 07:02 PM   #1
crank
crank's Avatar
Default 1956 lister d.
Hello all
Collected a farm fresh Lister d only five miles
From home gave it a wipe down and cleand the carb checked the governor wasn't stuck . Fitted a working
Mag. And after a while it was a runner.
Has a alloy cround pully with a v-belt pully on the end
And a well made shelf over the pully not home made.
Has any come across this before?
Thanks
Crank
crank is offline   Reply With Quote
Old 08-06-18, 08:00 PM   #2
That engine once powered an Alfa-Laval oilless vacuum pump Chris, the pump was mounted on that bracket.
Windrush is online now   Reply With Quote
Old 08-06-18, 10:04 PM   #3
crank
crank's Avatar
Hello Pete
Thanks. been looking for other similar
Engines. Going to keep it as is.
Part of its working history.
Do you still have the Lister shearing
Set.
Regards
Chris
Old 08-06-18, 10:35 PM   #4
Yes Chris, I still have the shearing set. I sold my other Listers recently but kept that one, it goes out a few times each year for an airing!
