Old 16-01-18, 09:04 AM   #1
Solsteam
Default Petter AVA 1 Cylinder Head
Just bought my first diesel,a Petter AVA 1. Will anyone tell me if this is the correct head for a series 1 or series 2 as it is different to the manual I downloaded. Secondly can anyone give me a date for serial 3136169S and as it was rebored etc according to the plate would this be the actual engine or renumbered when reconditioned?
Thank you.
File Type: jpg 018 Petter 'AVA 1' Ser 3136169S 20percent.jpg (99.5 KB, 12 views)
Solsteam is offline   Reply With Quote
Old 16-01-18, 09:12 AM   #2
Thank you.
Looks like a series 2 head. the Series 1 has a horizontal injector.
There are some variances, especially around the changeover from series 1 to series 2, but that does look like S2
Old 16-01-18, 10:03 AM   #3
Solsteam
Thank you Paul. At least all the parts will go together then.
Old 16-01-18, 10:31 AM   #4
If you email Jim Perkins he will be able to date your engine and confirm the head type.
jimp1115@btinternet.com
Old 16-01-18, 10:35 AM   #5
Agree that the pictured head looks like a series 2 item. If you are unsure what series your engine is, with the head off the series one has a flat top piston as it is indirect injection. As the series two is direct injection the piston on your engine should have a hemispherical combustion bowl in its crown..
Old 16-01-18, 11:04 PM   #6
Solsteam
Thank you Phillip, will do
Old 16-01-18, 11:05 PM   #7
Solsteam
Thank you Dan. With the piston shape it is definitely a series 2
Old 17-01-18, 12:46 PM   #8
Solsteam
Smile
Had an answer back from Jim Perkins saying that it is recorded as an exchange unit of March 1958. Also that is was originally a series 1. Probably explains the head and the fact that it has a series 2 piston. Thank you all for your help.
Tags
ava1, petter
