Old 03-09-17, 03:49 PM   #1
Nev B
Default Latest buy
i picked this up yesterday, single cylinder diesel , anyone like to guess what it is ? I,ve never seen one in the metal before , it looks like it should have a hose from the breather to the air inlet , the fitting on the side of the copper inlet unscrews .
The seller said it came from a school lab .
There is a makers plate but its in a very awkward place to get a clear picture .
Sorry about the clutter in the pictures , its been raining all day and I didn't want to get it wet
Oh nearly forgot , why does the spare injector have a wire on it ? the one on the engine has a little stub of wire remaining on it
Neville Bond
1940s Stuart Turner HY1
45 hp Gray Marine
Petter Mini Twin marine
Thornycroft DB2 Handybilly marine
1917? Fairbanks Morse two stroke
Nev B is online now   Reply With Quote
Old 03-09-17, 03:58 PM   #2
Wire is usually for a needle lift sensor.
Old 03-09-17, 03:59 PM   #3
Nev B
Thanks Peter , is that something that would permanently fitted or is it only used to test something ?
Neville Bond
45 hp Gray Marine
Old 03-09-17, 04:25 PM   #4
Well, for starters it's a Crossley, probably a BVC 1. I had one a long time ago.
Saw it recently at Astle Park.
(1914 1.5hp Bentall Pioneer); 1918 Renfrew 1.5hp;C.1919 1.5hp Simplicity; 1938 Lister D. 1.9hp; (1940 Petter ASX), undated 1.5hp Lauson Frost King.
pulsechoes is online now   Reply With Quote
Old 03-09-17, 04:40 PM   #5
Looks like Yours has an oil cooler fitted (the grey Serck gadget). Mine didn't have a leak-off on the injector where Yours seems to have something there, also mine had an original air cleaner/silencer fitted, with some sort of cold start gadget which looked like a stauffer greaser. Yours also has a water recirc pump fitted.
Old 03-09-17, 04:43 PM   #6
Originally Posted by pulsechoes View Post
(snip) some sort of cold start gadget which looked like a stauffer greaser.
Probably an ether cup as fitted to some Enfield diesels.
Old 03-09-17, 04:56 PM   #7
Nev B
Charles is correct it's a Crossley , the engine plate is fitted very low down behind the channel iron frame and I can't get to it to read it without lifting the engine off, I,ve not tried to start it yet, the oil has been over filled and I wouldn't want it to start throwing it up past the piston , I,ll drop it down a bit a rig up a tank and give it a go .
Neville Bond
45 hp Gray Marine
Old 03-09-17, 06:17 PM   #8
It goes with the test function of the engine, wouldn't be used commercially.
Old 03-09-17, 08:13 PM   #9
Horrible engine, I'd scrap it immediately!... there is a space, I mean a bin available in my garage
Old 03-09-17, 08:14 PM   #10
You've got one on order
