Old 14-08-17, 08:00 AM   #21
CAV offered an hydraulic nipple forming tool which worked on 6,8 and 10mm injector pipes.
Note that it is special thick-walled pipe, not regular fuel pipe.
Old 14-08-17, 11:29 AM   #22
I learned the hard way (expensive as well, but not to me thank heavens) many years ago that the pipe bore size is critical as well!
Old 14-08-17, 09:36 PM   #23
chrismac
chrismac's Avatar
Chaps here is a picture, now I know how to do it, of the injector pipe, hopefully you will see why I originally thought it was silver soldered or brazed on, after a clean up its clearer.
Untitled by chrismac2012, on Flickr
I was in contact with a firm in Newcastle who will make them up, ball park figure 20 per pipe,
Chris
Old 15-08-17, 09:37 AM   #24
1956ld1
1956ld1's Avatar
Those pipes look good compared to someone the ones I've reused on a tef 20...
Old 15-08-17, 11:32 AM   #25
chrismac
chrismac's Avatar
Unfortunalty, that was the only good nut and end, the pipes are in good condition its the nuts and ends that have suffered.
Chris
Old 15-08-17, 11:37 PM   #26
Are the ends not just the brass ends as used on fuel lines at carb and tank, 8mm or 5/16" size ?
Wolseley WD 8, Stuart Turner P5, Maytag 92, Kubota KND3, Maytag 72, Lister D Spec 11.
Old 16-08-17, 08:08 AM   #27
No, they are different and for a much higher pressures.
