Old 13-08-17, 08:59 PM   #1
chrismac
chrismac's Avatar
Default Injector pipes,
I have a project on the go just now, its not suitable for this forum though, its a small Iseki tractor, I joined another froum but I just feel its to big for me to cope with,
My question is regarding injector pipes, I need replacment ones and am unsure how to go about it, done a few google searches with little joy really,
I have the old ones so they could do as a pattern if I need to send them away, is this something a local tractor mechanic could handle? obviously I have not been to ask them yet, I am just at the inital stages of sussing this out yet.
thanks Chris
Old 13-08-17, 09:23 PM   #2
I would have thought that you would need a new one as a spare part rather than make one. Injector pipes are normally steel and not quite so easy to make.
Old 13-08-17, 09:33 PM   #3
chrismac
chrismac's Avatar
Thanks , yes they are steel, its the ends which corroded badly, the pipes are really okay, mmmm, not so easy a task then.
Old 13-08-17, 09:34 PM   #4
ant
Hi Chris
I see u finally got your tractor depending which engine it has you probably find them on eBay if its Mitsubishi engine same as mine which model did you get mines a tx2160 hydrostatic
Ant
ant is offline   Reply With Quote
Old 13-08-17, 09:35 PM   #5
Agreed. Pipe length is also critical and matched to the fuel pump and injector. Any Horticultural dealer/mechanic should be able to point you in the right direction.
Old 13-08-17, 09:35 PM   #6
dont they have the same ends as a brake pipe.
I would think any plant hire company could make you some or hydraulic pipe suppliers.
Old 13-08-17, 09:41 PM   #7
ant
I've bought parts for my tractor off this lad 07879993439 A few times and he knows quite abit about them
Ant
Old 13-08-17, 09:43 PM   #8
chrismac
chrismac's Avatar
Ant, yes its a TX2160, in a poor state, I actually got 2, K3B engines, not hydrostatic though, I have then engine out both, one stripped, they have been idle for about 15 years or so, but this one has not done much, not a lot of wear, I have been in touch with the ebay seller hndy compacts but it is all 2 cylinder parts he has at the moment,
Dan, thanks I was unaware that the lenght would have been critical, I will have to make some enquiries local to see who can help.
Martin P, the ends are brazed/silver soldered on by the looks of things, best described as being like gas bottle hose ends.
thanks Chris
Old 13-08-17, 09:44 PM   #9
chrismac
chrismac's Avatar
Thanks Ant I will maybe give him a call,
Chris
Old 13-08-17, 09:49 PM   #10
thanks Chris
Considering the pressures at the injector I wouldn't have thought silver solder/brazing would be strong enough.
