Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Diesel Engine Section
Old 06-09-17, 06:00 PM   #1
chrismac
chrismac's Avatar
Default Valve Lapping, New seats cut, Question
All, I am currently lapping in the valves on a mitsubishi 3 cylinder engine, I have given the seats a clean up with a valve seat cutter, my question is regarding the valves after lapping, I poured some diesel into the inlet ports should I be aiming for no leakage after lapping or is a small weep after an hour or so acceptable,
Thanks Chris
chrismac is offline   Reply With Quote
Old 06-09-17, 06:29 PM   #2
A "small weep" over that period of time will be fine Chris. We only left petrol etc in for about a minute to test seat/valve sealing.
Old 06-09-17, 07:13 PM   #3
Chippie
A uniform matt grey ring is what you are looking for......I usually pour petrol in, hold the valve by hand and count to ten....never had a fail yet....
Chippie is online now   Reply With Quote
Old 06-09-17, 07:24 PM   #4
chrismac
chrismac's Avatar
Thanks both for the replies, at least I know I am aiming in the right direction, all is good then.
Chris
