Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Petrol Engine Section
Old 17-02-18, 02:59 PM   #21
Harddisk25
Harddisk25's Avatar
I'm just rebuilding the carb today and i thought i ordered the correct bowl gasket but it was the wrong one. Which gasket set would i need on villiers services? Thanks
Harddisk25 is offline   Reply With Quote
Old 17-02-18, 03:45 PM   #22
Doesn't the manual give you the carb type?, I have manuals for my Villiers 4 strokes and they list the types of carb for each engine.
Old 17-02-18, 04:01 PM   #23
Check the manual I sent. The three carb variants each use the same washer Part no. V107. Same, I believe, as used in four stroke MK20/25 with Villiers carb. They are sometimes a tight fit so try a little lubricant
http://www.classicseagulls.co.uk/ind...product_id=245
Old 17-02-18, 07:14 PM   #24
Harddisk25
Harddisk25's Avatar
Thanks woodsman & Robotstar5. My head wasn't with it at the time and completely forgot about the manual you sent.
Old 17-02-18, 08:06 PM   #25
I think the carb is a Villiers lightweight.....
air-cooled is online now   Reply With Quote
Old Yesterday, 01:50 PM   #26
Harddisk25
Harddisk25's Avatar
You could be right air-cooled. Another bowl washer came and it's the same as the first.
My bowl washer measures 52.38mm. The ones i'm receiving are 49.50mm.
Old Yesterday, 03:18 PM   #27
I wonder if a soak in water would make it expand a little - and maybe soften it a bit?
Old Today, 02:12 AM   #28
Harddisk25
Harddisk25's Avatar
The gaskets are too small to stretch. I'm going to make one with gasket paper.
