Go Back   UK Stationary Engine Forum > Welcome! > Newbies, introduce yourself...
Notices
Old 15-06-11, 01:46 PM   #31
Mowersman
Mowersman's Avatar
No easy way to test it without specialst equipment.
Andrew
SE related; 1946 Petter A1 TVO, 1946 Lister D, 1940 Lister CS 5/1, 1963 Lister D, 1936 Lister B, Stuart water pump, Centrix lathe.
Non SE; Ferguson TED20, Various lawnmowers, rotavators etc, 1965 Series 2A Land Rover.
Mowersman is offline   Reply With Quote
Old 15-06-11, 02:08 PM   #32
fredfedfred
Do explain it can't be that bad
fredfedfred is offline   Reply With Quote
Old 15-06-11, 02:20 PM   #33
fredfedfred
Ok ummmm what are the other possible causes of no spark
definatly gonna change the ht lead as you call it. Maby an earth wire could help
if I were to use a coil what would I google to find one
Old 15-06-11, 03:25 PM   #34
Mowersman
Mowersman's Avatar
The next thing to replace would be the condenser, they regularly fail, I always replace them on any engine. To test it, you need a special tester that applies a high voltage to it, whilst testing for capacitance and leakage. Most places won't have them now as modern ignition systems don't need them. You’re lucky the coil is good as they are impossible to buy new and very expensive to get rewound.
Do you have a Maplins or RS components in Australia?
Andrew
Old 15-06-11, 03:44 PM   #35
Mowersman
Mowersman's Avatar
Right, give this a shot.
Condenser
Connect one let to a wire leading to the points, one leg to ground.
Andrew
Old 15-06-11, 11:27 PM   #36
fredfedfred
and take the condenser out??
so swap it for this capasitor??
ill have to try and order one
Old 15-06-11, 11:43 PM   #37
Mowersman
Mowersman's Avatar
Yup. A condenser is a capacitor, just under a different name.
Andrew
Old 15-06-11, 11:52 PM   #38
fredfedfred
ok just wondering what time it is over where you are
ive emailed a electronics parts shop i use regularly to se if they have on just put a link to that page and said "do you have"
should be able to get it this weekend.... if they have one
Tags
bsa
