Old 17-04-16, 12:34 PM   #1
listerlad
listerlad's Avatar
Default Lister CS Compression Valve
Can someone tell me how this is suppose to be used as I do not have a manuel for my CS.
Ollie
1945 Lister D, 1929 Lister A, 1946 Lister CS 3-1, 1948 Bamford EG3, 1941 Ruston & Hornsby 6PB, 1930 Ruston & Hornsby 8PB, 1948 Ruston & Hornsby PT, 1946 Wolseley WD II, 1927 Fairbanks Morse Z.
Old 17-04-16, 01:21 PM   #2
sinna42
sinna42's Avatar
That's an easy one to answer !
To increase compression you screw the valve in fully.
This makes the engine easier to start.
When running and under normal load conditions the valve is screwed fully out.
Jim
Here's a picture :
sinna42 is online now   Reply With Quote
Old 17-04-16, 03:32 PM   #3
listerlad
listerlad's Avatar
so I should wind it out a bit for running?
Ollie
Old 17-04-16, 09:00 PM   #4
jmcgrath
jmcgrath's Avatar
The valve can only be in or out there in no in between. if you got the engine running at a show at say 300RPM keep the valve in. if the engine is working and at rated speed then screw the valve out.
James
Too many engines to list
Old 22-10-17, 02:18 PM   #5
robert's rust
I have read elsewhere of people slow running a lister cs at 300/350 rpm while at shows, can someone explain how they slow the engine down so much, and why when lister state that the engine should rum at 600rpm (615rpm max)
Robert
robert's rust is offline   Reply With Quote
