Old 03-02-18, 09:07 PM   #1
PuttPuttBang
PuttPuttBang's Avatar
Default My first Lathe lots to learn
I will be picking up this Boxford lathe next weekend. It’s a 1979 AUD 5", apparently dry stored for the last 25 years and not much used before that, with no wear to bed or slides, we shall see. Comes with 3 and four jaw chucks and tail stock drill chuck as shown, plus “catch plate” whatever that is ? Presumably same as face plate ? Being an AUD it has a screw cutting gearbox and includes original splashback.
Anything else I need to ask for ?
Bad news, it is 3 phase so needs an inverter, can any one recommend one ?
I have a list of jobs to do and things to make.
Thanks for help and advice received on here so far.
PuttPuttBang is online now   Reply With Quote
Old 03-02-18, 09:19 PM   #2
Try Transwave, they have a website and they are in Birmingham.
Old 03-02-18, 09:26 PM   #3
PuttPuttBang
Thanks Martin, will do.
Old 03-02-18, 09:46 PM   #4
slatteybarn
It may be as cost effective to change the motor to single phase,and sell the 3 phase motor on
An inverter or a single phase motor are around the same price for a 3hp/2.2kw unit.230-260
regards
Phil.
Old 03-02-18, 10:08 PM   #5
Have to say that my lathe runs much 'nicer' in a rather indefinable way since I went from single phase to three phase and VFD. So if the budget allows, I think it's worth sticking with the existing motor and investing in a convertor.
Old 03-02-18, 10:16 PM   #6
Go for a VFD, you will get almost infinite speed control.
Old 03-02-18, 10:27 PM   #7
PuttPuttBang
What is VFD ? I would like to be armed with the latest terminology when I start speaking to suppliers. Also, Nick I am not sure I can have three phase on my 240v domestic supply, can I ?
I would like to stick with the existing 3 phase motor.
Old 03-02-18, 10:41 PM   #8
Variable Frequency Drive - little gizmo which takes in your normal domestic supply and spits out three-phase, with the benefit that you can alter the frequency and thus the speed.
Old 03-02-18, 10:45 PM   #9
Very nice, just wish I could have proper lathe, but lack of space means all I will ever is a micro lathe I reckon.
Old 03-02-18, 10:54 PM   #10
Chippie
Nice looking machine...
As an owner of several, converted to 3ph/vfd, lathes and milling machines, I have never aproached or bought from anyone like transwave....So unless you have deep pockets....go with them for whatever conversion suits your needs...
I can advise on what to buy if you need help......
