Old 19-08-13, 07:32 PM   #1
raggy 1
raggy 1's Avatar
Default Spark plug for wolseley w.d2
What plug do other forumites use in their wolseley w.d2s?I have been having issues with two different NGK plugs,a B6HS and a B6S.The engine runs very roughly on both even at various gaps.To make the engine run well i have to bring the choke lever back three notches from fully open.So what plugs are out there that are suitable for the wolseley?
raggy 1 is offline   Reply With Quote
Old 19-08-13, 07:37 PM   #2
I run (on Kenny aka WOOLSLEY)'s advice a B6HS and have no problems. However if the engine is running light I need half choke wheras on a milking set etc the lever can be pushed right forward. The same applies to my Ruston PT, it isn't happy when running light but under a good load choke isn't required.
Old 20-08-13, 12:11 PM   #3
raggy 1
raggy 1's Avatar
We did a few adjustments this morning(neighborours gone on holiday)and changed a few settings.We set the points to 14thou and a plug gap of 25thou.At those settings and with three notches back on the choke lever the engine runs quite well but the only spark plug it seems to like is a champion J8C which is the wrong plug but it runs well on it.
Old 20-08-13, 05:50 PM   #4
jmcgrath
jmcgrath's Avatar
I run mine on a Champion L90
James
Too many engines to list
Old 20-08-13, 05:57 PM   #5
It's quite normal for a Wolseley (not all, but many) on no load to require the choke back a few notches.
Although there is a long thread in the Wolseley head, the engine should be fitted with a 1/2" short-reach plug. If your magneto is good the Wolseley will run on absolutely anything that fills the hole! Mine have NGK B6s because they're cheap!
Old 20-08-13, 06:53 PM   #6
raggy 1
raggy 1's Avatar
The mag is good martin with a good coil(when bought it had a duff one)and a new condensor(duff when the engine was bought).It seems that when for a couple of minutes when the plug is getting hot the engine runs nice and even but as soon as it starts to warm up it starts miss firing and eight stroke at times.That the case when a NGK B6HS,L90,L81 and a Lodge CN is put in.Put a J8c in and its much better. Alan
Old 21-08-13, 08:29 AM   #7
Do you know the reason for a short reach plug in a long reach hole Martin? I can only assume it protects the plug, but it seems a bit odd. Surely it would promote fouling.
Old 21-08-13, 09:16 AM   #8
Don't really know, but R&H did it too, on the PB series; they fitted an elbow in the plug hole and the plug in the top of the elbow. One theory says it was just to protect the plug from getting bashed, whilst I've also heard it said that it prevented the plug from fouling.
Old 21-08-13, 01:35 PM   #9
Car manufacturers went the other way & used extended nose plugs that put the electrodes in the combustion chamber. I cant see how hiding the plug up a hole can prevent fouling. Still, what they did seemed to work, so what do I know:crazy:
Old 17-12-18, 10:47 PM   #10
slatteybarn
Wd engines will run with just about any plug that will screw it the hole and produce a spark.and from my experience it doesn't have to be a very good spark at that.my 1945 wd2 has the plug screwed in hand tight only, the plug is one that was knocking around on the bench 5years ago and it's only been taken out once in all that time and thst was to put in the mower.
Phil
