Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Petrol Engine Section
Old 11-01-18, 07:47 PM   #1
commerd
Default Amanco Hired Man
anybody help please it started when i got it,then it needed a new tank,now it wont start,and theres fuel coming out the breather
commerd is offline   Reply With Quote
Old 11-01-18, 08:09 PM   #2
slatteybarn
Have a look at the non return valve in the fuel line,they have a habit of getting stuck,
Regards
Phil
slatteybarn is offline   Reply With Quote
Old 11-01-18, 09:13 PM   #3
Dazzla
Dazzla's Avatar
If fuel is coming out of the carb them it's not the non-return.
Most likely it's choked or the spark is weak. Is it still on an igniter? Might be worth pulling it out and cleaning it up.
Failing that, I'll pop over one night and have a look if you want?
Dazzla
Sometimes it hits, sometimes it misses ...........
Dazzla is offline   Reply With Quote
Old 12-01-18, 06:28 PM   #4
commerd
thanks for that cheers,and good luck with things.
