Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Model Stationary Engines
Old 09-01-14, 12:17 PM   #1
Default Rowland engines
http://www.youtube.com/nrowland56
Things seem to have moved on a bit since I saw one of the early models (type B I think) running at the Anson a good few years ago now. While I'm not too keen on the aesthetics of some, they do look like interesting little things to play with.
Old 13-01-14, 11:09 PM   #2
deverett
I have owned a type D non-compression engine for a few years now. It always gets a lot of interest at the model shows I attend. Also have a set of Flame Engine castings maturing under the bench - a one day project.
Ignition has failed recently and I'm not sure whether it is the transistor or the coil that has blown. Transistors are cheaper than coils, so I will try replaceing that first. (There are only 2 parts - the transistor type TIP42c and the coil).
Dave
The Emerald Isle
deverett is offline   Reply With Quote
Old 13-01-14, 11:21 PM   #3
The D looks to me like what might have resulted if Gaudi designed engines!
