Old 11-03-18, 01:02 PM   #1
Cyberprog
WebHost
Cyberprog's Avatar
Default Piston Clocks
Hi All,
I don't post here that much, but figured you'd probably all appreciate these :)
I saw one of these recently on another forum I lurk on, and thought it would be a fun build. I have a friend at work who is very into his Audi's, so picked up an Audi piston as it has a nice cast Audi Logo on the Conrod.
Subsequently the reaction at work was very positive, so I made a couple more and took more photos. So, for your entertainment, here's the process!
So, we start off with a piston off eBay, in all it's cruddy glory!
The easy bits are split off here - top of the conrod, bolts and the rings/scrapers.
Next step would normally be to remove the snap ring that secures the gudgeon pin, but in the case of this particular piston (Mini R50 Engine) the conrod appears to be fixed to the pin - probably using heat, and I didn't have anything handy to release it. So I opted to just leave it in place. It makes cleaning the conrod harder, but it is still possible.
At this stage I then take the piston off and the conrod and run them through a wire wheel on the bench grinder, and clean up all the external muck. The bolts and top of the conrod (and pin, if removable) go through the same process.
I then clean up the inside of the piston using a degreasing foaming cleaner and then some isopropynol spray. That's then followed by the dremel clone with a small wire wheel/cup wheel to remove the hardened dirt.
And here's the finished result;
Next I setup the piston level, and then pop the bubble on the conrod and use a welding magnet to stabilise things.
A couple of blobs of weld hold the pin to the piston (I'm working on making this neater!) and we have the cleaned piston ready for measurement.
With the right measurement I can then order a suitable clock insert, and that will usually have a rubber ring round the outside which grips nicely into the top of the conrod. In the picture below, the one we've been working on is the smaller of the two.
Alex Threlfall
Cyberprog New Media
www.cyberprog.net
Cyberprog is offline   Reply With Quote
Old 11-03-18, 01:31 PM   #2
Nice work. Rather than welding I would suggest using a high-strength Loctite, it hides in the joint and will be plenty strong enough for this application. Done this a few times at work to make leaving gifts for various folk out of scrap engine parts, I work in diesel R&D so plenty of bits around!
Old 11-03-18, 01:33 PM   #3
Loctite 648. With the joint properly cleaned and fully coated with 648 it will never move again!
Old 11-03-18, 02:49 PM   #4
One of my workmates is a total BMW freak (no, I don't get it either) and would I'm sure love one of those made from an appropriate piston assembly.
Old 11-03-18, 04:42 PM   #5
Cyberprog
WebHost
Cyberprog's Avatar
I'll order a tube and try :) Thanks!
Had a Merc piston arrive this week, so I've spent the last hour or so cleaning that one up. Handily the same size clock as the Audi one, so a quick swap and I've got some pics of it :)
Alex Threlfall
Cyberprog New Media
www.cyberprog.net
Old 11-03-18, 05:03 PM   #6
Cyberprog
WebHost
Cyberprog's Avatar
I've had a look, and there are some cool looking m-sport ones, but none have any logos on. Seems only a handful of manufacturers put them on the castings.
Mercedes, Audi, VAG, GM are the ones I've ID'd so far.
Alex Threlfall
Cyberprog New Media
www.cyberprog.net
Old 11-03-18, 06:11 PM   #7
woodsman
Made a lady petrol head friend a garden wind chime from a scored piston and some big washers.
Regards Paul
