Old 03-02-18, 10:55 PM   #11
Chippie
Variable Frequency Drive - little gizmo which takes in your normal domestic supply and spits out three-phase, with the benefit that you can alter the frequency and thus the speed.
Nice little IMO inverter, very reliable and reasonably priced...
Old 03-02-18, 11:10 PM   #12
PuttPuttBang
PuttPuttBang's Avatar
Ah I see, that looks good
Old 03-02-18, 11:21 PM   #13
The programming taxed my poor old analogue brain but apart from that, all good.
Old 04-02-18, 09:48 AM   #14
Nice looking machine...
As an owner of several, converted to 3ph/vfd, lathes and milling machines, I have never aproached or bought from anyone like transwave....So unless you have deep pockets....go with them for whatever conversion suits your needs...
I can advise on what to buy if you need help......
Pockets dont have to be that deep, I am looking at finally converting my lathe to a three phase motor and Transwave can supply a motor, direct fit, VFD and control panel for 360, all I do is fit it and programme the VFD to my requirements.
Old 04-02-18, 10:15 AM   #15
RobSmith
RobSmith's Avatar
Have to say that my lathe runs much 'nicer' in a rather indefinable way since I went from single phase to three phase and VFD. So if the budget allows, I think it's worth sticking with the existing motor and investing in a convertor.
Definitely. My lathe was appauling during the time it had a single phase motor on it.
I now have a vfd on it.
Old 04-02-18, 10:19 AM   #16
RobSmith
RobSmith's Avatar
I think your catch plate might be that big piece of chequer plate behind the lathe.
It is worth having and worth keeping clean to reflect the light around the work.
Old 04-02-18, 01:31 PM   #17
Catch Plate - Face Plate.
Old 04-02-18, 07:47 PM   #18
RobSmith
RobSmith's Avatar
Well there's a thing
Not seen or used one of those before.
I guess you clamp your work to it with half a dozen G clamps and then go for 3000 rpm
Less dangerously.. i guess you turn things between two centres and use that as a drive
Old 04-02-18, 09:06 PM   #19
Brian Davis
Just done this with my Boxford. I bought a cheap vfd from eBay for 90 and installed it myself. I have the same motor as in your picture. Be aware that it is 415 3 phase even though it says 220 and 415. It wasn't just a case of changing the three bars over to make it 220v. I had to take it to a motor rewinder to change it over. Didn't cost a lot though. It's the difference between star and delta. I'm no expert.
I would definitely keep it 3 phase though, variable speed , reverse and motor braking are great.
Brian Davis is offline   Reply With Quote
Old 05-02-18, 04:52 PM   #20
PuttPuttBang
Thanks Brian that is useful info.
I have spoken to Drivesdirect.co.uk, and basically if the motor is dual voltage (e.g. 220/415V) then it can be driven at either voltage. Of interest is the horsepower, that will determine the size (and cost) of the inverter required. I may need a new "pot-in-a-box" (whatever that is). I will need to know how to change over the motor voltage, so that would be good info ?
Basically I need to get the lathe home and in the shed so I can see what I have got.
