Go Back   UK Stationary Engine Forum > Main Engine Section > Suppliers > Tanks, Taps, Pipes, Sheet Metal etc
Old 17-07-17, 06:26 PM   #1
Kleftiwallah
Default 270 degree bend.
An easy one for chaps of your calibre. How do I put the tightest 270 degree bend in a length of 5/16" copper tubing?
The other alternative is a 180 degree bend one way, then a 90 degree bend t'other. It's to get the fuel from the tank tap into the engine compartment.
Over to your knowledgeable selves Cheers and thanks in anticipation. Tony.
Kleftiwallah is offline   Reply With Quote
Old 17-07-17, 06:33 PM   #2
5/15???
I assume you mean 5/16? Easiest way is to fill with sand and plug the ends if you don't have a proper pipe bender, it is possible to use a bolt and pair of washers and do it around that. Or make a jig.
Old 17-07-17, 06:53 PM   #3
eddie78
Second on the sand trick works very well
Old 17-07-17, 07:01 PM   #4
Kleftiwallah
Thanks appletop, you're a star. Amended to 5/16".
I have thought about cutting a semi circular groove of the correct diameter in a bit of nylon (or something similar). It's going to be awfully fiddly filling such a small diam' with sand. Would salt do the same job?
Cheers, Tony.
Old 17-07-17, 07:03 PM   #5
Before you attempt the bend heat the area and either side to glowing red and allow to cool, this will soften the copper and will be easier to work, the sand idea is a well known method and works well.
Old 17-07-17, 07:06 PM   #6
Cheers, Tony.
Salt is likely to crush to powder and will liquefy if heated sand will not if you need to reheat to soften
Old 17-07-17, 07:11 PM   #7
Indeed, you can get really fine sand easy enough, wouldn't recommend Ballast tho....
Old 17-07-17, 07:12 PM   #8
As Martin says, anneal first. Sand might be a bit fiddly but works provided you can fill the pipe. Easier, and equally successful is the bolt with 2 washers method - not good for larger sizes, but works fine for small tube.
Having said all that, small tube will generally bend perfectly well round a form (bit of steel tube?) without crushing or kinking, provided it's annealed first.
Old 17-07-17, 07:28 PM   #9
Kleftiwallah
Do I carry out this annealing with the sand inside the tube or before?
(Do I leave the tube to cool in the air or quench in water)?
Cheers, Tony.
Old 17-07-17, 07:32 PM   #10
You could try Cerrobend otherwise known as wood's metal or Resin WS8 but it's expensive.
Edit: just to clarify, they're 2 different products.
