Old 16-04-18, 09:43 PM   #1
Default Morris 8 Engine workshop manual
Knowing that quite a few members are involved with historic vehicles, would anyone happen to have a workshop book/ manual for the Morris 8 side valve engine?
Many thanks,
Old 16-04-18, 09:49 PM   #2
slatteybarn
Any good to you Phill
http://www.worldofrarebooks.com/the-...xoC9eAQAvD_BwE
Link only take you to their site they have a workshop manual,just under.£18.
Phil.
Old 16-04-18, 09:49 PM   #3
What do you need to know Phill? I have a 1940's book that includes the Morris Eight series E engine/gearbox/ axle and body.
Old 16-04-18, 09:52 PM   #4
I've taken on the rebuild of one of these engines and would just like to have any information that may be available. It's such a simple thing but it can be really useful to have figures for ignition timing, clearances, that sort of thing.
Old 16-04-18, 09:56 PM   #5
Can get you settings tomorrow, they are a doddle to work on. Pistons/conrods come out from underneath past the crankshaft like most engines from that period. Something you have to watch, there is a gasket on the tappet sideplate that must be fitted the correct way up so take note!
Old 16-04-18, 09:59 PM   #6
That would be great Pete, thanks! It's in "basket case" condition but pretty much all there.
Old 17-04-18, 06:01 AM   #7
wacker
Also the f
FLYWHEEL HAS TO GO ON BEFORE THE SUMP
wacker is offline   Reply With Quote
Old 17-04-18, 09:28 AM   #8
When i started work in 1962 (20 years ago) Jim who i worked with gave me a set of 4 motor engineering books one of which has data sheets. just pulled one.--Morris 8,series E (1945-48) -918cc --Bore & stroke 57x90mm. ---Comp ratio 6.5 to 1.---valve clearances (hot) .017in---Valve timing marks. Bright chain links & sprocket marks.---V/timing inlet opens 8 derees btdc--- Piston removal,downwards---firing order,1342.---timing marks on timing cover & pulley---Timing.TDC fully ret.---s/plugsChamp L10---Plug gap .022.--- Coil type (lucas)6q6---Distributor type (lucas) DKYH4A---Carb,SU---Type H1---Jet size .090--metering needle EK---Battery 6v 51 A.H.---Rear axle,Spiral bevel, ratio 5.286:1,Adustable by shims.--Steering, toe in 1/8 in.---OIL-Eng 3o sae 6 pints--G/box 140 1.5 pints---Axle 140,1 pint.---Steering box 140.---Tyre pressures F 24--R27. Hope that helps Missed out a few bits like dynamo & starter type .Good luck with the car
Old 17-04-18, 10:05 AM   #9
Brilliant, thank you!
Itís for a tractor, it has a Solex carburettor, belt drive governor and Lucas dynamo.
Old 17-04-18, 10:07 AM   #10
Georgineer
Our family business was a Morris Agent and had various workshop manuals including the Morris 8. They were given to the National Motor Museum at Beaulieu in the late eighties before the business closed down. I don't know what arangements the NMM has for access to such things, but it might be worth asking. My recollection is that the Morris 8 manual had a lot less information than the later Morris Minor book.
George
Georgineer is offline   Reply With Quote
