Old 24-03-18, 11:23 PM   #11
cccst70
Default drive side
If you fitted pulley onto the other side of mill on the lower shaft that would make it run slower than powering it off the hand crank shaft as the larger toothed gear on there speeds up the movement.
cccst70 is offline   Reply With Quote
