Old 11-12-17, 07:49 PM   #1
philipagri
philipagri's Avatar
Default Rise and Fall table saw
Snow prevented me from going to the sale in Ledbury on Saturday so I went to a local sale instead and came back with this interesting pulley driven rise and fall sawbench that I thought would look good with an engine. Unfortunately someone has removed the nameplate and I wonder if anyone knows who made it?
I believe there should be a guard over the top of the saw and there are two bolt holes on one corner of the table that might be for it.
I assume the rod operated hook mounted halfway up the pedestal is for changing from fast to loose pulley but again I can't see how it works as the rod only turns or pushes through the pedestal and doesn't seem to have any sideways movement, is there something missing here too.
Thanks, Philip
Old 11-12-17, 07:51 PM   #2
philipagri
philipagri's Avatar
Here is the other photo which I wanted to upload
