Go Back   UK Stationary Engine Forum > Main Engine Section > General Issues
Old 14-03-18, 08:50 AM   #1
Default Working out what gear to order.
Hi, I need to replace the magneto gear on a Ruston APE as it has two damaged teeth. I have looked on the HPC website and I need to work out the DP of the old gear to order a replacement. Do I measure the distance between the teeth or is there a formula I need to work to or is it a case of the number of teeth Vs the diameter? Sorry if this is a silly question but I don't want to order the wrong one!
Dan_pt is offline   Reply With Quote
Old 14-03-18, 09:33 AM   #2
Headless
Headless's Avatar
What is the outside dia and number of teeth, from that I can look up the DP and pitch dia.
Andy
Visit Internal Fires eBay shop http://stores.ebay.co.uk/Internal-Fi...id=p4340.l2563
Headless is offline   Reply With Quote
Old 14-03-18, 09:34 AM   #3
sinna42
sinna42's Avatar
All you need is the Outside Diameter & the No of Teeth.
OD = (N+2)/P
OD = Outside Diam
N = No of Teeth
P = Diametral Pitch (DP)
For Metric gears
Module = 1/DP
And therefore Module = OD/(N+2)
Hope that helps !
Cheers,
Jim
Too many engines & not enough space !!
sinna42 is offline   Reply With Quote
Old 14-03-18, 10:19 AM   #4
Thank you for the help. I will measure it later on.
Old 14-03-18, 10:31 AM   #5
Do HPC still do a paper catalogue? It used to have useful full scale silhouettes of various tooth profiles which was a big help in identifying.
Old 14-03-18, 10:40 AM   #6
I have no idea Nick. I just looked at their website. The gear I need is under 2" diameter so should be quite reasonably priced. Hopefully all tht will need doing to the new gear is to have a taper machined into it to suit the magneto shaft.
Old 14-03-18, 11:26 AM   #7
I was also wondering about the paper catalogue, the printed tooth profiles are very useful. Not least because there is another variable; gear teeth also have a pressure angle, and they're not all the same.
I have found the HPC gears are very high quality but tend to be quite thick. There's a fair chance you will also need to slim it down a bit.
Old 14-03-18, 05:59 PM   #8
I have measured my gear and it comes out at between 1.77 and 1.8 inches depending on where I measured it
Using the above formula it comes out at 10 DP. Does that sound right?
It has 16 teeth.
Old 14-03-18, 06:19 PM   #9
Chippie
Based on your info, HPC gears list one, their G10-16 comes in at 16 teeth and 1.8 in diameter, 21 ish....plus carr
A 10 dp gear cutter in hss is about the same price....if you got a mill and indexer to make your own gears....
Chippie is offline   Reply With Quote
Old 14-03-18, 06:20 PM   #10
Headless
Headless's Avatar
Looking in the Machinery Handbook it is 10 DP.
Andy
