Old 20-03-17, 10:47 PM   #1
listerlad
listerlad's Avatar
Default Trailer
Thinking of buying a small trailer, something but enough to carry a engine and pump but only around the 400-500kg mark? Anything recommended? Would be towed behind a 2009 Kia Rio 1.5 CRDI.
Ollie
Lister D x2, Lister A, Lister CS 3-1, Bamford EG3, Ruston & Hornsby 6PB, Ruston & Hornsby 8PB, Ruston & Hornsby PT, Amanco Hired Man, Fairbanks Morse Z, Stuart Turner P4, Alco Featherweight.
Old 20-03-17, 11:03 PM   #2
I've got an Erde 142, (replaced by the 143) Does the job behind my 1.4 diesel Yaris. Pulled this 400 odd miles no issue.
DSCF5447 by Stephen Williams, on Flickr
Old 21-03-17, 06:39 AM   #3
listerlad
listerlad's Avatar
I do have my late granddads Erde 102, (little bit small) just wondered about strapping points? was thinking about a maypole trailer?
Ollie
Old 21-03-17, 08:39 AM   #4
I've got u bolts which are bolted down with steel plates to spread the load. Rear ones are removable to allow larger engines in the back.
Old 21-03-17, 10:37 AM   #5
Look out for a decent second hand "Paxton" trailer on Ebay, far better built than the "Erde" type. I got a close look at an Erde at a local crank-up recently and a friend has one too and they really are one step up from a biscuit tin. (sorry Steve!!) That's just my personal opinion.
or try these:-
www.ebay.co.uk/itm/142302910630
Numquam illegitimo carborundum. 1918 Renfrew 1.5hp;C.1919 1.5hp Simplicity; undated 1.5hp Lauson Frost King. 1933 Quentin C1.
Old 21-03-17, 10:43 AM   #6
You need to be careful though, Your car can only tow 453 kg unbraked!!! (according to the spec website.)
Old 21-03-17, 10:58 AM   #7
Also remember that that limit is the gross weight stated on the trailer plate so you would be technically illegal even with an empty 500kg trailer!
Old 21-03-17, 11:54 AM   #8
Yes been looking at that.... need to change my car then....
Old 21-03-17, 12:01 PM   #9
I think it would be a particularly bloody-minded traffic cop (or a certain camping stove collector ) to enforce the letter of the law on that one Steve.
Old 21-03-17, 12:11 PM   #10
I'm still not convinced that I was correct when I wrote that the other evening. Trouble is; I haven't found any better info - and the .gov websites don't help.
If this is actually true then there are a great many people (I suspect) towing trailers, but more probably caravans, that exceed this limit.
