Old 17-02-18, 07:15 PM   #1
darren
Default Lister D water tap bung
hi iv been trying to remove the water tap bung. it must have been snapped of at some point and someones had a go at rethreading it and made a right mess of it. anyway iv been trying to remove the plug with out any success even tried the heat gun and wond budge. wonderind if anyone has any advice they can give me.
darren is offline   Reply With Quote
Old 17-02-18, 09:08 PM   #2
Hi Darren,
If the bung is beyond repair then you could weld a large nut to it and use that to remove it. They don't yield easily sometimes.
Old 17-02-18, 09:16 PM   #3
chrismac
chrismac's Avatar
Could you drill and re-tap it next size up, leaving the bung in place? fitting a reducer then when done, they are never good to work with in my experiance I leave them well alone,
Failing that you could get a carbide burr and remove metal top and bottom, if still no movment get a hacksaw blade and cut the last bits out through the threads, see if you can get some movment that way.
What has snapped, the 2 flats that the spanner would have gone on?
Chris
Paul bet me to it, with a good idea, as the heat will help break the bond between the 2.
Old 17-02-18, 10:52 PM   #4
darren
the water tap must have been snapped off at some point. there is also a bit snapped off where the spanner would go making it even more dificult.
