Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Engine Identification
Old 26-11-17, 01:56 PM   #1
Noah Hemlock
Noah Hemlock's Avatar
Default Petter A ?
Hi everyone I could do with a bit of assistance, I have a petter A but from all the research I have done it would suggest that they only made them 1.5 to 3 bhp, but mine clearly shows 5 bhp. I have two theories for this; either that it was a special of some kind or that it has been miss labeled. if anyone has any ideas or has heard of a 5 bhp petter please do speak up.
Thanks - Noah
Noah Hemlock is offline   Reply With Quote
Old 26-11-17, 02:12 PM   #2
Interesting.
Some A types came in higher hp than 3 and normally had increased engine speed to get the extra hoss. The 1.5jp was at 750 rpm, what's the engine speed of yours? That could point to it either being a special or a mis-stamped spec plate, and also give Jim Perkins an email, he may be able to shed some light on it as well.
Old 26-11-17, 02:48 PM   #3
Noah Hemlock
The engine speed is 750 and as i have just been looking i have discovered that there is a crude 1 scratched in front of the 5 so i recon this solves my problem :)
Thanks - noah
Old 26-11-17, 05:59 PM   #4
Reckon so, if it runs at 750 then it'll be a 1. 5 hp.....
Old 26-11-17, 07:31 PM   #5
Yep, it would have to be a fair sized engine to produce 5bhp at 750.
Most likely a 1.5hp that has been mis stamped. the 5bhp example would be 1650rpm.
