Old 23-01-15, 12:32 PM   #11
Also, as you have said they are deeper than the old ones, check that the rings don't bottom out in the grooves.
Old 23-01-15, 12:49 PM   #12
Ring gap in the bore should be 3 thou per inch of bore diameter (not circumference ) If i remember correctly. Check it in several places in the cylinder in case of wear. The wear ridge at the top of the bore can cause new rings to hit it. "Ridge jumper" rings were available years ago for car engines. I've seen a slight chamfer ground on the top compression ring to avoid the wear ridge (Very slight) in the past. Or you can use a "Ridge reamer" to remove the ridge. I mention the ridge reamer because i have one (the only one i've ever seen, Snap On one, 15 at a rally,as new. Dont think the chap knew what it was) Or you can just fit new rings Probably be ok.
Old 25-01-15, 09:37 PM   #13
Lee C
Lee C's Avatar
Blimey, just had a look and can't actually get the rings in the bore as the gap closes completely. Is it normal to grind the ends of the rings to get them to fit? Also I need to make sure the rings don't bottom in the piston. I find it strange as they are sold as Lister D rings.
Lee
Lee C is offline   Reply With Quote
Old 25-01-15, 10:08 PM   #14
Quite normal to have to adjust the gap, shouldn't be a problem. I just do mine with a file, saves taking too much off.
Old 26-01-15, 07:02 AM   #15
Lee C
Lee C's Avatar
Thanks Phil,
apologies if this is all basic stuff, but it's all new to me and I want to hone these skills.
I'll post some pics for interest when I can as I am manufacturing a new brass dipper at the moment too as the old one sheared off when trying to unscrew.
Lee
Old 28-01-15, 07:16 AM   #16
Lee C
Lee C's Avatar
A few pics attached of progress showing the manufacture of the dipper.
Old 28-01-15, 07:20 AM   #17
Lee C
Lee C's Avatar
A few more pics after filing and polishing..
Old 28-01-15, 02:29 PM   #18
Lee C
Lee C's Avatar
Hi all,
With regard to the new piston rings that I intend to fit, they fit the grooves precisely, i.e. the outer face of the rings are flush with the side of the piston.
Should I be worried about this as I am reckoning there is no room for expansion as the cylinder heats and piston could seize.
Thanks in advance.
Lee
Old 28-01-15, 02:44 PM   #19
Have you put a ring into a bore, without the piston if it wont go in the open ends need filling to increase the gap until the ring goes in, there is a maximum gap you must not exceed but I'm not sure of size but somebody will tell you, you need to do this for every ring.
Old 28-01-15, 03:09 PM   #20
As normally quoted by Peter Hepworth: 3 to 4 thou gap, per inch of bore diameter. A little more for aircooled engines. Must be gapped for the tightest part of the bore; only experimentation will tell you where that is.
