Old 17-01-16, 06:48 PM   #1
timothygstokes
timothygstokes's Avatar
Default Bench mounted pillar drill
Hi all, I won a bench mounted vintage pillar drill on ebay a few days ago, and I finally took delivery of it yesterday. It's in a good, clean condition, and it isn't very heavy regarding weight. My only issue is I have no idea of who made it. The only markings I can find on the drill are "TB" and "No 14", which are cast into the main body on the left if the drill is facing me. My first thought is Record for the manufacturer, as I have seen quite a few Record items with "No 14" cast into them somewhere. Please find attached a photo of the markings, and a photo of the drill overall.
Cheers ,
Tim
edit: could one of the admin rotate the pictures the right way up please? I don't know how to do it on here
Archivist for The Unofficial Lister D Type Owners Register
1945 Lister D Type 1 1/2 HP(26DH196040), 1942 Briggs & Stratton Model I (63981), Villiers C12 Gen Set (257351), Climax Water Pump.
timothygstokes is offline   Reply With Quote
Old 19-01-16, 12:11 AM   #2
timothygstokes
Just thought I'd bump this up, really curious as to the manufacturer. If anyone has any information on this type of drill, or similar makes, then please comment
Old 19-01-16, 01:48 AM   #3
I've no idea of the maker, but it's a lovely looking thing. I bet you are well pleased with it.
Old 19-01-16, 09:35 AM   #4
These things were made in their thousands, by hundreds of manufacturers, and they were all very similar. The "No.14" is no help; many manufacturers used similar idents. Unless you stumble across an identical item you will probably have to settle for not knowing. Even if you do find an identical drill, there's every possibility that it was contract-made by a 3rd party manufacturer so it might have been called something else...
Old 19-01-16, 05:54 PM   #5
timothygstokes
Thanks Jules, I am really pleased with it to be honest. It came with a small pulley on it instead of the flywheel, but it also came with the flywheel so I bought a puller so I could get the pulley off and fit the flywheel instead.
Thanks
Tim
Old 19-01-16, 05:54 PM   #6
timothygstokes
Oh, okay. Thanks for the information Martin
Tim
Old 19-01-16, 06:01 PM   #7
ListerHA2
ListerHA2's Avatar
If you Google "hand pillar drill" and then go to images a lot of useful images pop up.
http://www.lassco.co.uk/a-vintage-pillar-drill
Old 19-01-16, 06:23 PM   #8
I inherited Anne's Grandfathers old Union pillar drill on his death and it has been sitting in my shed for Donkey's years now. I actually found a use for it a couple of years ago, I used it as a press to fit the recessed valve spring collets into a diesel Escort van cylinder head! Apart from that it hasn't been used since I have owned it, however I know darn well that if I ever do decide to sell it I will then encounter a task that it would have been ideal for!
Old 20-01-16, 01:13 PM   #9
timothygstokes
I think i'd have a hard time doing that job with mine . And, if you ever do decide to sell it, put me down on the list of potential buyers .
Tim
Old 20-01-16, 01:16 PM   #10
timothygstokes
Thanks for that, I'll have a look when i'm not in college.
Tim
