Old 09-10-17, 08:57 AM   #1
skint
skint's Avatar
Default Paraffin
Hi
Im looking for a supplier of paraffin for my handyman
any recommendations,
Im in surrey
cheers Paul
1937 ruston 1xhr, petter s type 3x5hp,6hp,8hp, petter appletop 5hp,3hp,2hp,1.5hp petter acorntop 2hp,1.5hp,petter bogtop 1.5hp
petter handyman 2 1/4hp
skint is offline   Reply With Quote
Old 09-10-17, 09:07 AM   #2
PuttPuttBang
PuttPuttBang's Avatar
Originally Posted by skint View Post
Hi
Im in surrey
cheers Paul
I found paraffin was very expensive in comparison to Kerosene (heating oil) which is essentially the same thing. You can pay up to £2.00 a litre for paraffin, while heating oil is 30p to 40p a litre depending where you buy. You can buy kerosene in filling stations, it is more expensive, but still a lot cheaper than paraffin.
Experiment by adding a little petrol to the kerosene to find a nice mix your engine is happy with.
Old 09-10-17, 09:54 AM   #3
skint
skint's Avatar
Thanks for the info Mark
I did get recommended paraffin blue for it by a fellow owner
but its like trying to find hens teeth lol
cheers paul
Old 09-10-17, 10:00 AM   #4
I can remember when you could buy it in hardware stores for paraffin heaters used at home one local shop even had a vending machine that would dispense a gallon into your container outside shop hours!.
Old 09-10-17, 10:09 AM   #5
slatteybarn
You may have to look around for a reasonably priced supplier.It can be brought from B&q and the likes but you wil pay a pre-packed premium. Try rural garage/service stations.
One of our local garages does paraffin on the pump £5.65 a gallon(or whatever the metric is)and the other garage in the village does Red desiel on the pump.
Phil
Old 09-10-17, 10:11 AM   #6
listerlad
listerlad's Avatar
Rye Oil LTD supplies it in 25 litre cans, might be worth a trip to rye unless you know your going to use loads of it, they will probably deliver if your within 50 miles.
Ollie
Lister D, Lister A, Lister CS 3-1, Bamford EG3, Ruston & Hornsby 6PB, Ruston & Hornsby 8PB, Ruston & Hornsby PT, Fairbanks Morse Z, Stuart Turner P4, Alco Featherweight.
Old 09-10-17, 10:33 AM   #7
Roddy
I buy paraffin for a greenhouse heater. Local hardware shop sells it in 4litre bottles for about £8.00. Haven't seen it in bulk for years now.
Roddy is offline   Reply With Quote
Old 09-10-17, 12:24 PM   #8
Not quite the same quantities required, but I went to my local DIY store on Saturday thinking I’d be able to buy a gallon container of paraffin for my lamps... “Paraffin, no chance mate”..
Will visit the garden centre on the way home, they usually sell it. I can recommend Rye oils for good service though, I’ve found them very helpful.
Old 09-10-17, 05:27 PM   #9
Winter of 1993 to Feb 2003 I was buying paraffin by the gallon at the rate of about 5 gallons a week as my only heating fuel, can't remember how much is was across that period, but I'd guess still less than £2 a gallon towards the end.
Old 09-10-17, 06:36 PM   #10
ListerHA2
ListerHA2's Avatar
28 second heating oil (Kerosene) works well in lamps or engines. I just visit my Son and siphon a gerry can full every now and again
