Old 09-02-18, 08:21 PM   #1
Headless
Headless's Avatar
Default Stuart P5M
A friend is struggling for info on a P5m re the mag drive. His appears to be missing part or parts of the drive mechanism. Please does anyone have a parts diagram which shows these parts.
Andy
Old 09-02-18, 09:21 PM   #2
I don't seem to have a manual for the P5M (I did once so don't know where it's gone....)
IIRC they are the same as the P55M were it is chain driven to a sprocket with a gear on the same shaft, which in turn drives the water pump.
Old 09-02-18, 10:01 PM   #3
Headless
Headless's Avatar
Thanks for that, I will pass the info on.
Andy
Old 09-02-18, 10:11 PM   #4
I have a manual which covers both, main illustration is identical to the one which Steve posted but there is also one with a bit more detail on the coupling - see attached.
Old 09-02-18, 10:19 PM   #5
Headless
Headless's Avatar
Thanks will pass that on, he should be able to work out what if anything is missing now.
Andy
Old 10-02-18, 11:18 AM   #6
Bit more information from the P5 parts list:
Old 10-02-18, 11:29 AM   #7
Headless
Headless's Avatar
Thanks for that Peter, I have forwarded that on.
Andy
