Old 16-11-17, 11:43 PM   #31
Eleven
Originally Posted by Headless View Post
Now you have removed that item you have also removed the peg that operated the impulse mechanism. You will probably find that the cam is also wrong as there are many different orientation available.
There may be a intermediate piece between the drive from the engine to the mag or the mag may have the female to the engines male part.
Nuts, which item do you mean sorry? And what does the peg look like?
Eleven is offline   Reply With Quote
Old 16-11-17, 11:47 PM   #32
Headless
Headless's Avatar
In post 25, 5th picture the peg with screwdriver slot in it, is at the top of the alloy plate.
Andy
Old 16-11-17, 11:49 PM   #33
Eleven
Ok that hasn't been touched at all - only the 4 screws that hold the end plate on (this is not one of them) were undone, then done back up again. The screwdriver slot was left alone.
Is it still likely to be mucked up?
Old 17-11-17, 12:04 AM   #34
Headless
Headless's Avatar
Sent you a PM
Andy
Old 17-11-17, 12:10 AM   #35
Eleven
Replied :-)
