Old 19-08-17, 11:59 PM   #1
Default Briggs & Stratton Magneto
Yes I know it's a mere youth at 30 years old but I've got no spark on the old ride-on mower. Tried holding the HT lead a few mm from the engine while turning it over and no spark. I understand how a points driven system works, but this one has a magnet in the flywheel to induce current in the coil and I can't get my head round how it's wired. One end of the HT coil is connected to the frame with a ring terminal and the frame is bolted to the engine to complete the circuit, the bit I don't understand is a second ring terminal under the same bolt goes to a wire on the ignition switch which grounds it to stop the engine, how does grounding an already grounded wire stop the engine???
I must have my stupid head on today as there can't be a much simpler ignition system
Mag02R by Robert Starr, on Flickr
Old 20-08-17, 11:48 AM   #2
keith-pu8
keith-pu8's Avatar
An ignition coil has two copper coil windings, a primary and a secondary winding.
The primary is a thick wire and the secondary in a very thin wire, which is the wire that breaks and stops the coil working 99% of the time.
A picture of a villiers coil I did may help.
keith-pu8 is offline   Reply With Quote
Old 20-08-17, 11:56 AM   #3
Chippie
Keith,
Are you saying you rewound/re-manufactured a Villiers coil?
If so, please elaborate.....
Old 20-08-17, 12:24 PM   #4
As far as I can see/test, there is only one winding, there is no LT side as no points to switch it, it seems to work purely by induction of the magnet in the flywheel?.
Old 20-08-17, 01:08 PM   #5
dannysdriver
Default Briggs and stratton
I think you have a magnetron ignition coil which did away with the points and condenser on later briggs engine,They could also be retrofitted to older engines.
dannysdriver is offline   Reply With Quote
Old 20-08-17, 02:28 PM   #6
hortimech
Yes that is a magnetron coil and if you haven't got a spark, then there are several things you can check. What is the airgap between the coil legs and the magnet in the flywheel, it should be about 25thou. do you have a spark if the stop wire isn't connected the coil, much time has been spent testing coils etc when the fault is the OPC system (oops OPC = Operator Presence Control). If the airgap is correct, the magnet in the flywheel is magnetic and there isn't a spark with the stop wire disconnected, they it sounds like you will need to airtest the coil and find a new one.
hortimech is offline   Reply With Quote
Old 20-08-17, 03:08 PM   #7
keith-pu8
keith-pu8's Avatar
No, this was just a 3D picture I did to show a Villiers coil.
I have wartime and MK1 coils on my motors, plus a hand full of spare complete ignition systems, as you do.
They do re-manufacture most if not all villiers coils, even twin spark, which I already have, but they are pricey, a long villiers wartime coil, is about 65.
Old 20-08-17, 04:34 PM   #8
Chippie
Ahh..ok.
Thanks for the reply anyway.....65! Yeeeeouch!..
I have engines not worth that....
Old 20-08-17, 09:00 PM   #9
Originally Posted by Chippie View Post
Ahh..ok.
They wont be worth very much at all without a spark!
Old 20-08-17, 09:02 PM   #10
I think 65 is a good price for a working magneto coil.
