Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Ignition Systems
Old 21-01-18, 11:16 PM   #11
raymondo
Have a look at the coils from minimag if you need a small coil I recently built a complete minituare system using their bits.
raymondo is offline   Reply With Quote
Old 22-01-18, 12:15 PM   #12
If the low tension side of the existing magneto is good you could try wiring it up to LT side of the coil. Worked for my Villiers MK10 and at least you have eliminated the battery
