Go Back   UK Stationary Engine Forum > Member's Area > Events & Rallies Information Section > Events / Rallies General
Old 09-07-18, 08:18 PM   #1
electrocutas
electrocutas's Avatar
Default stationary engines at Helmsley
https://youtu.be/D2ExMbe4q14
Pete -
1 x Wolseley wd1 - 2 x Wolseley wd11 - 1 x Wolseley wd8 - Bamford EG1 - Bamford EV3 - Bamford EG4 - Yet to be identified Bamford - R&H PT1 - loads of other stuff
electrocutas is offline   Reply With Quote
Old 10-07-18, 08:49 AM   #2
woodsman
Thanks for posting.
Was going to come over but family matters took over. Maybe next time.
Regards Paul
Old 10-07-18, 10:10 AM   #3
Thanks for posting the video, but I did struggle to watch it as the frame rate appeared to be "stopping" the flywheels and peoples movements where very jerky. I thought it might be my end so checked a couple of your other videos, one looked normal (flywheels spinning and peoples movements were fluid) but the other had the same effects as the first, were you using different cameras?.
Old 10-07-18, 10:21 AM   #4
electrocutas
MMmmm its the digital camera its ok on fast connections.
Had to go digital as Transferring from tape just takes too long and I don't have the spare time
Pete -
Old 10-07-18, 10:49 AM   #5
That must be it then, I've checked a few more of your videos and it looks like you went digital for the 2018 season? , I'll confirm the theory when I get to work as they have a silly fast BB connection.
Old 10-07-18, 01:06 PM   #6
It's not the connection - I'm connected to the internet at 84Mbps and Youtube at 46Mbps. The video, however, is only 854 x 480 resolution, at a claimed 30fps - clearly, once it has been uploaded and processed by Youtube, it's nothing like 30fps.
Just in case there's any doubt about connection, I am running diagnostics and so far I have dropped 3 frames out of more than 7000.
Old 10-07-18, 03:07 PM   #7
I got to agree, I have been subscribed to you videos for a while now, and have enjoyed them, however the last few have been hard to watch because of the frame rate thing. Now I'm afraid I take a quick look at all your uploads, but if their looking a bit weird, I'm afraid they don't get watched
Old 10-07-18, 03:16 PM   #8
chrismac
chrismac's Avatar
So is it a YouTube issue?
I am lost already,
Although I was going to reply earlier but bit my lip.
Chris
Old 10-07-18, 06:48 PM   #9
I am lost already,
Chris
The problem is the settings on the video camera, frame rate is too slow, or record quality set low, for smaller files making for ease fast uploads.
Old 10-07-18, 08:06 PM   #10
electrocutas
no its hd 30fps
Its the process that You tube run on it.
Slapped wrist.. Must try Harder !!!
Pete -
