Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Marine Engines and Accessories
Old 05-08-17, 09:10 AM   #11
Originally Posted by Nev B View Post
Giving the pistons a soak in Coke for a few days, I,ve tried Diesel, ATF and acetone , various penetrating fluids with only one piston giving up the fight , the other 3 are stuck fast so nothing to lose with the Coke , apparently the phosphoric acid in the Coke does the trick , we shall see .
I find that works for me too Nev. If i mix in 25% of Jack Daniels it loosen's me up no trouble.
Old 01-07-18, 05:43 PM   #12
Nev B
Well after a lot of frustration and cursing the engine ran for the first time today , I had to replace the pistons which I managed to track down in Canada , the starter motor hadn't enough life in it to spin the engine over but I was very lucky to be given a modern one that fit straight onto the engine , the Dynamo isn't fitted yet , it needs a bracket making to hold it in place , there's a drive shaft that goes from the back of the Dynamo to the water pump .
Still a way to go yet but at least it runs
Picture is a bit blurry, sorry
Neville Bond
1940s Stuart Turner HY1
45 hp Gray Marine
Petter Mini Twin marine
Thornycroft DB2 Handybilly marine
1917? Fairbanks Morse two stroke
Nev B is offline   Reply With Quote
Old 01-07-18, 05:56 PM   #13
Always a good feeling to hear them running for the first time
Old 02-07-18, 09:20 AM   #14
Wow, sounds great, Nev, just need a boat now!!!
Old 02-07-18, 11:14 AM   #15
minorman
minorman's Avatar
That's a nice piece of kit. It really does beg for a boat to fit it in. Well done.
minorman is online now   Reply With Quote
Old 02-07-18, 11:40 AM   #16
Very nice mate, good work. That has come out very well.
Old 02-07-18, 12:02 PM   #17
Nev B
No boats for me , very much a fair weather sailor, a bit of a swell and I turn green :-(
Neville Bond
45 hp Gray Marine
Old 02-07-18, 02:50 PM   #18
No swell's on a canal!!
Old 02-07-18, 05:54 PM   #19
Nev B
Mrs B would disagree with you , we went for a trip on my brothers canal boat once and she had to take motion sickness tablets !! No waves obviously but people moving about making the boat rock was enough !
Neville Bond
45 hp Gray Marine
Old 02-07-18, 08:45 PM   #20
Sorry, but your making a really good case for buying a boat
