Old 21-03-17, 08:07 PM   #21
Originally Posted by pulsechoes View Post
Yes Nick, they mean the same thing, though I tend to associate GTW with commercials.
ISTR VIN plate on the Wagon R actually stated GTW - must look at the one on Roomster.
Old 21-03-17, 08:16 PM   #22
(snip) GCW, same as Gross Train Weight. MAM, Maximum Authorised Mass. Why the hell can they not stick to just one set of terminology?
I guess terms involving mass are more general as they will mean the same even if you get pinched on another planet, whereas weight will of course vary with local gravity.
EDIT; An excellent example of the authorities thinking ahead.
Old 21-03-17, 11:25 PM   #23
From my dim and distant Physics lessons, I seem to remember that mass is a constant but weight can vary with the amount of gravity it is exposed to.
Mass is the "amount" of matter an object contains. A 1 tonne block of lead has a mass of 1 tonne and a weight of 1 tonne at sea level. Take it into outer
space and it still has a mass of 1 tonne but weighs progressively less the further away from Earths gravity it travels, until it becomes weightless.
The Planet Earth has a virtually incalculable mass ( billions upon billions of tonnes) but no actual "weight". It just hangs in space like a party balloon.
Old 30-04-17, 03:46 PM   #24
listerlad
listerlad's Avatar
Visted a local rally. Was looking at the maypole trailers that The Wagon Works from Canterbury had to offer. Nothing really looked suitable for me. Looked too short to accommodate my lister junior. Looks like to have another look around or change the car for a Fiat Doblo or similar which is what I should of done.
Ollie
Lister D x2, Lister A, Lister CS 3-1, Bamford EG3, Ruston & Hornsby 6PB, Ruston & Hornsby 8PB, Ruston & Hornsby PT, Amanco Hired Man, Fairbanks Morse Z, Stuart Turner P4, Alco Featherweight.
Old 07-08-17, 03:31 PM   #25
listerlad
listerlad's Avatar
I was thinking about putting my Fairbanks Morse Z 1.5hp on the little Erde 102 in the garage but there's a lack of tie down points. Was only going to tow behind my grey fergie but don't know where I could strap to, best to be safe than sorry.
Ollie
Old 07-08-17, 04:26 PM   #26
IMHO those "Erde" trailers are fine for keeping biscuits in. Looking closely at their construction, if You put tie downs in it and put tension on the straps, they would probably fold up!! They would be OK for tents and sleeping bags but not much else.
Old 07-08-17, 05:53 PM   #27
Lined the bed and sides of my 142 with plywood and use U bolts with spreader plates without a issue, fine for smaller engines but my genset is pushing its limits.
Old 07-08-17, 06:41 PM   #28
If it's similar construction to the 121 I have, there is a 2" SHS "axle" that carries the indespension units about 4" below the trailer floor. Fit upstands with spreader plates on between the "axle" and the floor which will give you a couple of "hardpoints" to fit tie down eyes to.
Old 08-08-17, 10:23 AM   #29
listerlad
listerlad's Avatar
Sounds like a board it out and put spreader plates in.
Ollie
Old 08-08-17, 11:28 AM   #30
...or get rid of the Toys R Us "My First Trailer" and get something a bit more robust?
