Go Back   UK Stationary Engine Forum > Main Engine Section > Suppliers > Ignition, Magnetos, Plugs etc
Old 05-07-18, 03:09 PM   #11
Definitely going then - I need to have a long hard think about B&S 'lifeboat' set.
Old 05-07-18, 06:28 PM   #12
Well Nick if it isn't being shown at rallies etc then it might as well go. Says me with a whole load of stuff that hasn't seen daylight for ages or still requires finishing off!
Old 13-07-18, 04:41 PM   #13
Mister_D_Lister
Mister_D_Lister's Avatar
Finally got chance to have a look at the Wico A. Unfortunately the ignition condenser I ordered is too big for the mag so it's lashed up externally having removed a points cover clip to allow me to screw it into its mounting hole for earthing.
Spun the mag over by hand - the spark seemed bigger so went for broke & put it on the engine. Filled the carb, fitted the plug and pulled it over with the rope - it started first pull taking me completely by surprise .
Clearly although the condenser looked ok on a meter there was enough leakage to suppress the spark under compression.
I have another condenser on order, hopefully this one will fit inside the mag!
1934 Stuart Turner R3
1953 BSA 300W charging set
Mister_D_Lister is offline   Reply With Quote
Old 13-07-18, 05:08 PM   #14
Chippie
Oh....deep joy, glad you got it running....
Chippie is offline   Reply With Quote
