Old 06-12-17, 11:44 AM   #1
Default Ruston 6 AP Timing.
Hi, can someone advise me of the correct timing for the spark on a 6 AP with a BTH magneto. (How many inches BTDC on the flywheel?)
Many thanks Dan.
Old 06-12-17, 11:59 AM   #2
Timing marks on the magneto gears and on the sideshaft gears, Dan.
Old 06-12-17, 12:10 PM   #3
Thanks Peter.they are in line but the gear can be fitted in any position on the mag shaft. It runs but is a little noisy from the exhaust suggesting it may be a bit retarded. I guess some experimentation is in order.
Old 06-12-17, 12:11 PM   #4
If I can find the AP booklet on my desk, I'll see if there is any timing info.
Old 06-12-17, 12:16 PM   #5
Found the AP 'Useful Information' booklet, nothing at all on magneto timing I'm afraid.
Looked through the other AP literature that Ray Hooley sent me, nothing there either.
Old 06-12-17, 12:21 PM   #6
Thanks for looking Peter. I'll give it a couple of degrees extra and see how it goes.
Old 06-12-17, 01:38 PM   #7
A strobe light might work Dan.
Paul_Sterling is online now   Reply With Quote
Old 06-12-17, 03:19 PM   #8
I've tried it on a BPR Paul - it's hopeless. The magneto HT will trigger the strobe, and it can be powered from a seperate supply, but the strobes were all over the place. I suspect too low rpm, governing, and the vageries of the magneto all contributed.
The Wico EK Ruston AP has a small advantage, because you can vary the timing whilst running. It was interesting, and I discovered a very small change made a real audible difference to the exhaust note. I think it's worth continuing to play...
Old 06-12-17, 04:33 PM   #9
I suspected so Martin, the Strobe is aimed for a 1000rpm running speed.
Old 06-12-17, 05:04 PM   #10
Probably 20 BTDC, Or maybe 18
Not that it's the same but I can measure the CPR at the weekend, mag gear on that is keyed.
