Old 06-12-17, 07:37 PM   #71
One of those was the starting point for Dad's Stirling engine model and defined the scale. He said it was a good quality casting and clearly it fitted in the ML7 ok. Agree with you that it would look a bit skinny on your engine though.
Old 06-12-17, 07:42 PM   #72
Steam flywheels best avoided - they can't take the compression/ignition shock.
martinpaff is online now   Reply With Quote
Old 07-12-17, 08:56 PM   #73
Engineers Emporium do a selection of cast iron flywheels for ic engines.
Old 10-12-17, 04:01 PM   #74
Hi Phill,
Flywheels are in this album http://www.stationary-engine.net/for...hp?albumid=892
1) 4 straight spokes - 8 1/4 inch diameter, 1 3/16 inch wide, bore 5/8 to 11/16 inch (tapered), weight 3.2kg
2) 4 curved spokes - 11 13/16 inch diameter, 1 9/32 inch wide, 11/16 inch bore, weight 4kg.
I had a look at your earlier pictures and the crankshaft looks a fairly big diameter....
Have you had a look at the EE flywheels, some were pictured in the SEM Dec/Jan issues (Partsmart).
Old 10-12-17, 10:38 PM   #75
Hi Phillip,
Yes I have looked at the EE flywheels and they are certainly an option, but I would like something with a bit of "patina" if possible, it will help with the appearance.
I like either of those flywheels and will check the measurements against the engine and the lathe again tomorrow. The one with the taper bore could be winner as I was intending to secure the flywheel on a taper.
I think the size of the crank is deceptive really, the whole thing is really quite small.
Thanks, will be in touch,
Old 06-01-18, 11:50 PM   #76
Thanks to Phillip, I now have a suitable flywheel.
It has a taper bore and the crank will be machined to suit.
IMGA0115 by Phillip Sheppard, on Flickr
Many thanks,
Old 07-01-18, 12:22 PM   #77
I was having problems earlier trying to get the scale of your engine as there was nothing in the previous photos to give an idea of size. That flywheel matches your engine well and looks pretty OK in my opinion.
Old 07-01-18, 01:06 PM   #78
Yes it really is quite small, it's likely it will be a bit frantic like small power machines often are; but the heavy flywheel should help.
Old 07-01-18, 01:15 PM   #79
Series gearbox first motion shaft in the background?
Flywheel looks good.
Old 07-01-18, 01:36 PM   #80
pulsechoes
pulsechoes's Avatar
Best clutch plate aligning tool on earth, an original shaft. Better than shelling out for a tool with loads of sizes that You'll probably never use!!
Numquam illegitimo carborundum. 1918 Renfrew 1.5hp;C.1919 1.5hp Simplicity; 1938 Lister D. 1.9hp; undated 1.5hp Lauson Frost King. 1933 Quentin C1.
pulsechoes is online now   Reply With Quote
