Old 23-05-16, 10:05 PM   #1
Matt_Hedges
Matt_Hedges's Avatar
Default Lister A type
Hi all, collected a Lister A yesterday that I have been waiting to collect for 18 months, it's a 1948 spec A29 and its on a original Lister A trolley. It has sat in the guys shed for over 15 years and not been touched. The exhaust valve was stuck open, governor linkages were partially stuck, cam follower was stuck open and the fuel tank was full of loose corrosion.
Today I have oiled and freed the linkages, stripped and rebuilt the fuel pump, freed up the exhaust valve, freed up the cam follower. I used pebbles and fuel to clean the inside of the fuel tank and will use tank sealer to finish it of. I then cleaned the points, put a new plug in and tightend up everything and gave her a swing. After about 5 swings she fired and went for over a hour with no issues. Im very pleased with how it has turned out.
https://youtu.be/AD7v8AWQnQQ
Thanks, Matt.
Matt
1936 reverse rotation Lister D, restored lister H1, 1929 shaft drive Lister D, unrestored lister H1, Bamford EV1 1944, Ruston 6PB 1938, Lister H2, Norman T300 lighting set
Matt_Hedges is offline   Reply With Quote
Old 23-05-16, 11:06 PM   #2
2010macjac
2010macjac's Avatar
Sounds lovely I do miss my A must buy another one
Old 24-05-16, 12:24 AM   #3
I hope you changed the engine oil and cleaned the sump out too before firing it up?
Old 25-05-16, 09:39 PM   #4
Scott
Hello all
Congratulations are in order. A really nice find of an original looking A on it's original trolley. And well done on getting her going again. Spectacular is the word I'm looking for.
I notice she sounds like she's starving for fuel a bit. It might be worthwhile to check the fuel level in the carbi. I'd also check the timing and/or spark.
Cheers Scott
Old 29-05-16, 03:57 PM   #5
Matt_Hedges
Hi thank you for all the comments, I have checked the timing this afternoon and put a new HT lead on and a new plug. I then adjusted the governor. I had it running for a hour this afternoon and think it is running a lot better now, what do you think ?
https://youtu.be/xJyFzSE4F_0
Thanks Matt
Matt
Old 01-08-16, 08:58 PM   #6
Scott
Hello Matt
That's made a world of difference. You've got to be happy about the way she runs now.
Cheers then
Scott
