Old 04-07-13, 11:22 PM   #1
Rookesy
Default Serial Number
Gents,
If the brass plate is missing on a Lister A where would I find the serial number please?
Mick
Rookesy is offline   Reply With Quote
Old 05-07-13, 06:52 AM   #2
Flywheel rim usually.
Old 05-07-13, 03:49 PM   #3
Rookesy
Peter,
Thank you, the rims had been painted but I found the numbers, 260690, the same on both flywheels. If I am reading the dating chart right it was made in late 1945. I'll write to David and get more details.
Mick
Old 29-09-15, 09:09 PM   #4
brianl
Default number on flywheels
Does anyone know where the numbers are on a lister A Flywheel.I can not find them possibly due to paint. Inside or outer rim will help.
Thanks Brian L
Wolseley wd8 x2. Ruston Hornsby pt. wolseley Wd 1. Wolseley wd2
brianl is offline   Reply With Quote
Old 29-09-15, 09:51 PM   #5
Default Lister A serial number.
There!!! Take note of the position of the keyway on the shaft
Old 29-09-15, 09:52 PM   #6
The serial number should be stamped on the flywheel face, that's the bit that faces the sky and the ground at the same time. EG it's not on the side/rim of the flywheel. There should also be a '1' or a '2' stamped under each serial number, these are flywheel numbers to identify which side each flywheel is fitted to.
If you are still struggling to find it then let me know and I'll take a photo of the number on one of the flywheels on my Lister A, so you can see the shape and location of what you are looking for. Hope this is useful.
Old 29-09-15, 10:13 PM   #7
brianl
Found the numbers now I was looking in the wrong place. Thanks for the help gents.
Brian L
