Go Back   UK Stationary Engine Forum > General Transport Section > Towing & Trailers
Old 22-05-18, 05:51 PM   #71
Bridge weight limits are simple enough, if it states '17 tonne GVW limit' then you shouldn't cross it with anything that is plated for carrying more.
Old 22-05-18, 05:55 PM   #72
Having read this thread from the beginning I havent got a bl**dy clue what you are all on about.
Old 22-05-18, 06:03 PM   #73
Lucky for you that you are old enough so it doesn't matter then isn't it....
Old 22-05-18, 06:19 PM   #74
That's a relief Martin, you won't be reporting any of us for being 2 Drachms over the allowance according to line 3, paragraph 8, chapter 29 of regulation 3456-456-567-5678-4567 which we all should know about as it was available for viewing in a basement in Schleswig-Holstein for twenty minutes last Wednesday fortnight.
Old 22-05-18, 06:54 PM   #75
It might matter as I'm restricted to 3.5 ton as I inject Insulin. Knowing my luck they have changed that to.
Old 22-05-18, 11:09 PM   #76
“But the plans were on display…”
“On display? I eventually had to go down to the cellar to find them.”
“That’s the display department.”
“With a flashlight.”
“Ah, well, the lights had probably gone.”
“So had the stairs.”
“But look, you found the notice, didn’t you?”
“Yes,” said Arthur, “yes I did. It was on display in the bottom of a locked filing cabinet stuck in a disused lavatory with a sign on the door saying ‘Beware of the Leopard.”. (Douglas Adams fans will understand)
Old 22-05-18, 11:24 PM   #77
Yep, unashamed plagiarism!
