Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Petrol Engine Section
Old 11-09-17, 08:55 PM   #11
Dazzla
Dazzla's Avatar
Surely if it's a hit'n'miss the exhaust tappet clearance should be huge, about 3/4"?
I suggest before you tear anything off or adjust other bits you set the tappet so that the exhaust valve opens a maximum of 1/4" and try that. I suspect you've adjusted it so far the detent can't latch and arrest the pushrod.
Dazzla
Sometimes it hits, sometimes it misses ...........
Dazzla is offline   Reply With Quote
Old 12-09-17, 07:50 PM   #12
listerlad
listerlad's Avatar
Location: Sat in the Garden of England, enjoying the sunshine
Ran it up tonight, sounded perfect until it went back to running really fast. So it was stopped and on further inspection there appears to be a spring broken! Part of the latch mechanism.
I know it's not the best of pictures but it was the best I can do.
Ollie
1945 Lister D, 1929 Lister A, 1946 Lister CS 3-1, 1948 Bamford EG3, 1941 Ruston & Hornsby 6PB, 1930 Ruston & Hornsby 8PB, 1948 Ruston & Hornsby PT, 1946 Wolseley WD II, 1927 Fairbanks Morse Z.
listerlad is offline   Reply With Quote
Old 21-09-17, 02:18 PM   #13
listerlad
listerlad's Avatar
Can't work out what's causing this now. Just runs uncontrollably and has to be stopped.
Ollie
Old 21-09-17, 02:23 PM   #14
chrismac
chrismac's Avatar
post removed
chrismac is offline   Reply With Quote
