Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Hot Air / Stirling Engines
Old 12-11-17, 11:07 PM   #1
Default Henrici query.
I'm posting this on behalf of a friend. He wants to know exactly what the function is of the item in the attached photograph marked "Petroleum". I was told that it is a cylinder oiler, but whatever is put in it just runs straight through. It is basically similar to a Stauffer Greaser and the hole in the bottom is around 1/8" with no "restriction".
Old 12-11-17, 11:26 PM   #2
Dazzla
Dazzla's Avatar
I've seen a few with that, usually smaller ones. I'm told a splash of 'petrol' is required occasionally. Quite why I don't know.
I've got a bigger engine, but that hasn't got a pipe/filler and it runs ok.
Dazzla
Dazzla is online now   Reply With Quote
Old 12-11-17, 11:28 PM   #3
Oils piston and displacer rod guide. Not too easy to see the details but looks like it might have a needle like those inverted bottle plummer block lubricators.
Old 13-11-17, 12:34 PM   #4
OK, thanks for that, Gents. Sounds like a splash of oil in there prior to a run will be OK.
Old 13-11-17, 12:48 PM   #5
The German word "schmiervorrichtung" in Nick's illustration means "lubricator". I know that doesn't move us forward any; just for interest.
Old 13-11-17, 01:12 PM   #6
Danke vielmals. I do understand basic German and could converse a little, but am now "out of practice". The former Mrs Hamilton was a Swiss National.
Literally translated it means "Grease device". Very explicit language, German, some of it's words used to make me laugh!!
Old 13-11-17, 01:25 PM   #7
Indeed!
Exhaust = "Auspuff"
Old 13-11-17, 02:45 PM   #8
When i worked for a German owned company I seem to recall the engineers telling me there was quite a difference between "technical" & "conversational" language?, we had to use a specialist company to get some of the equipment manuals translated.
Old 13-11-17, 02:55 PM   #9
Dazzla
Dazzla's Avatar
I had the same translating some technical/scientific drawings and guides from Italian into English. Regular translation guides were utterly useless.
Dazzla
Old 13-11-17, 02:56 PM   #10
Indeed!
Exhaust = "Auspuff"
How about Dudelsack = bagpipes!!
Krankenhaus= hospital
bustenhalter = bra
durchfall (literally through fall) = diarrhoea.
There are many many more!!!!
