Old 10-05-18, 09:39 PM   #1
Default Centec 2
Having just about given up on finding a small milling machine that will fit in my tiny workshop, I was offered this little Centec 2 whilst working at Duxford yesterday. It turned out to be just a few miles from the workshop and I collected it this evening.
I found the machine just as described, well abused and in need of restoration and repair. It probably won't happen quickly but I'll post updates as I go.. it just cost me the fuel to get it so I don't mind a bit of work. The rear bearing housing is missing but I'm told it is likeley to turn up in the P/O's garage at some point!
When finished, it will be a vast improvement over milling attachments on my lathe - there are a few jobs waiting for it too.
Untitled by Phillip Sheppard, on Flickr
Old 10-05-18, 10:01 PM   #2
And as a bonus you got to christen the new trailer and test the tie down eyes
Old 10-05-18, 10:02 PM   #3
Headless
Headless's Avatar
Testing the tie downs already.
Andy
Old 10-05-18, 10:05 PM   #4
I've got a Centec 2A, but I dont know what the difference is, there is also B, there doesnt seem to be much visual difference, your table appears to have seen some abuse.
Old 10-05-18, 10:15 PM   #5
To repair the table, I was thinking of milling the damaged areas to take sections of plate, this restoring the Tee slot profile and then re-finishing the table on the surface grinder. Something I have seen done to good effect on several small machines.
The tie down points are brilliant, as is the trailer. I really cranked the straps up tight and nothing so much as creaks. The trailer is much better with a load aboard and the leaf springs are freeing off nicely for having some oil sloshed over them..
Old 10-05-18, 10:24 PM   #6
Bonus of towing behind a Landy!
Old 10-05-18, 10:26 PM   #7
A very solid tow vehicle, you don't really know it's there!
The automatic chassis lubricator is working very well, I need to take the overdrive off to replace a couple of seals soon.
Getting better at reversing in straight lines having had a bit of practice..
Old 10-05-18, 11:08 PM   #8
Is there a vertical head available for these little mills ?
Old 10-05-18, 11:48 PM   #9
Georgineer
I have a Centec 2 but regrettably it's in pieces awaiting a place in my workshop. There's a limited amount of information available on the internet but I'm happy to share what I have if you PM me Phill.
There are vertical heads available, but they are very scarce and tend to go quickly for lots of money.
George
Georgineer is offline   Reply With Quote
Old 11-05-18, 05:54 AM   #10
slatteybarn
Nice find. The mill was also badged as Warwick and as Hobson both companies are stil around so the may have some infomation
As for a vertical head.I think it is something that Phill is certainly more than capable of making.especialy as he now has all the tools.
Phil
