Old 09-05-18, 03:18 PM   #1
darren
Default lucas rs1 problem
hi i have a lucas rs1 magneto which i have just replaced the bearings points and condenser. it gives of a descent spark but its lyk the whole mag body is live because you get a shock when your spinning it by hand and touching the ht lead. should really do that but has anyone got any advice on what the problem could be. regards Darren
darren is offline   Reply With Quote
Old 09-05-18, 03:21 PM   #2
If you have the body in your hand and you are touching the HT lead you will get a shock as the magneto body acts as one of the wires otherwise the magneto wouldnt work.
Old 09-05-18, 03:51 PM   #3
darren
thanks for the reply martin. it still does the same when it is mounted on the mag bracket or is that normal. regards darren
Old 09-05-18, 05:21 PM   #4
You could try not touching the ht lead, they tend to give a shock
Old 09-05-18, 05:53 PM   #5
darren
i know iv learned that lol
Old 09-05-18, 06:47 PM   #6
The body of the mag is the earth that the leads shorts to (sparks)
If you want to test it while holding the mag you need the HT lead to short to the magneto body without you touching the end of the lead, so hold it an inch or three away from the end and maintain an ⅛" gap for the spark to jump.
PS: shocking yourself while testing is easy to do, makes you jump a bit but that's all, however touching the top of plug and the engine while it's running will give you a proper shock
Old 10-05-18, 06:17 PM   #7
Crash Test Johnie
Crash Test Johnie's Avatar
When replacing the bearings did you fit new insulating shims as this could cause a problem.
Crash Test Johnie is offline   Reply With Quote
Old 10-05-18, 08:19 PM   #8
darren
no i never actually it did nt have any on. do these go on both ends
Old 11-05-18, 02:56 PM   #9
Isn't the RS1 a moving magnet job - no need for bearing insulating shims.
Old 11-05-18, 06:56 PM   #10
The Lucas SR1 mags have the insulating shims Nick so I reckon the RS1's will have as well?
