Go Back   UK Stationary Engine Forum > Main Engine Section > The Workshop > Tricks of the Trade
Old 26-10-14, 11:26 PM   #1
Default Gib head key removal.
Something that some people suffer with...
Removal of Gib head keys. I made a start in making my little smoker a bit better looking today so thought I'd take a photo or 4 of how I get keys out, was a waste of time as the sodding thing fell out more or less! But here goes.
Clean key, as this one was. If your key is suffering burs or hammer abuse then get a file and trim it up till it looks "Key shape"
Slide the wedge in the gap. My wedge is a "home made" job, it is 3/8 plate and has a taper from 1/16th to 1 inch, the face is also slightly tapered to allow it to "dig in" to the key, put it in the other way round and it will just fly out.
Clamp to hold it in place. I normally use a slightly bigger clamp than this and also a packer strip on top but when I did that the picture wasn't that clear.
My other wedge, this is a direct pattern from a Claas one, I only use this after the small one has got the key moving in the first place, failure to do so and to go straight in with the bigger wedge tears the heads off.
And finally, the video...
https://www.youtube.com/watch?v=PpXGxtr534M
Sorry, looks a bit easy!!!
Old 28-08-16, 05:39 PM   #2
Dreamweaver 1
Did exactly as above,both gib keys came out a treat,without any damage,well recommended extraction method.
David
1927 Crossley P60
Dreamweaver 1 is offline   Reply With Quote
Old 28-08-16, 06:05 PM   #3
Yip. That's how I get all my keys out and so far only struggled with one. Trouble is with the Petter in the photos and video it was just too easy!
Old 28-08-16, 06:36 PM   #4
CSdiesel
Great. now do one with lost head keys usually found rusted in on D type flat belt pulleys
CSdiesel is offline   Reply With Quote
Old 28-08-16, 06:39 PM   #5
Get hydraulic puller and pull the pulley off. Easy....
Old 28-08-16, 08:11 PM   #6
Remove the pinch bolt, fill screw hole with your favourite freeing agent, leave to stand, repeat until the agent starts to seep out around the shaft. Clean any exposed shaft, and then do as Rob suggests and use a puller to remove the pulley.
Old 28-08-16, 08:59 PM   #7
CSdiesel
I got one here where some ham fisted bugger has sheared the pinch bolt off flush !! Grrrrrr
Spec 11 too so got to come off somehow
