Old 21-02-16, 08:01 PM   #1
williams8781
williams8781's Avatar
Default Reavell compressor exhibit
Hello all, what do you think of this compressor for an exhibit? It has a good motion to it and should look good with the two drip oilers.Waights 500+ kg. Any comments and information welcome.
Most run.....
williams8781 is offline   Reply With Quote
Old 21-02-16, 08:52 PM   #2
Lovely thing. As an exhibit to take to a show I would forget it. Ask yourself, will the public appreciate half a ton of compressor at a show? Without a certified pressure vessel you are limited to making raspberry noises with it. I would use my haulage capacity to take a larger engine.
Old 21-02-16, 09:20 PM   #3
williams8781
True,weight isn't so much of an issue as I would take on the fordson major but as you see alot of space too. Also it would use up a nice set of wheels and time. Might keep it as a shed toy
Most run.....
Old 20-05-16, 08:31 AM   #4
Dave Inglis
With a compressor that size you could make a really impressive bubble machine - that would draw the crowds!
Dave
Dave Inglis is offline   Reply With Quote
Old 20-05-16, 11:01 AM   #5
Dave
Yes, most of them to say stop blowing that sticky ******* bubble mixture all over the paintwork on my engine!
Old 20-05-16, 12:40 PM   #6
Dave
You could blow into plain (or coloured) water. (No bubble mixture) With one that big. It'd be impressive if done right.
