Old 01-05-13, 05:21 PM   #11
Originally Posted by steve-v12 View Post
I'm sure you recently made some derogatory comment about Petter A1's ??
Steve :)
Me??
Maybe in jest. I will admit to seeing the A1 as "Another Petter A1" but I do like them as an engine, and I have always turned to them when I wanted a power source for something, first shed had a 3hp A1 on a genny for power, first mixer had a A1, and I have had 3 sawbench setups over the years with A1 Petters on them.
Old 01-05-13, 06:16 PM   #12
Default Belt and Puylleys
While looking at the saw and engine I thought to myself, do I need a 4 vee pulley/belt setup? My saw has been running with 3 belts now for about 3 years now with no problems, now I want to replace the pulleys as they are pitted quite badly and was wondering it a 2 vee pulley would be good enough or should I stick to 4vee?
Old 01-05-13, 09:10 PM   #13
jsg1586
jsg1586's Avatar
Originally Posted by Appletop View Post
I know what you mean John but I think the PAZ will do better on the saw than sitting on a rally field slowly carboning up!
Plus I do have a soft spot for the A1 Petter...
Not the best looking things at all, but having had a few A1's myself, I know what you mean.
Simplicity does it for me - I like simple, compact engines that are easy to work with.
John
jsg1586 is offline   Reply With Quote
Old 18-06-13, 07:45 PM   #14
Been a bit slow this one but today I ordered myself a set of pulleys, belts and also some new bearings for the saw as the drive side is a bit "roomy", about 1/8" of room to be honest.
Am now thinking of a way I can mount the whole thing on wheels to make moving it easy, got to be easier to move the saw to the wood pile than move the wood pile to the saw!
Old 26-06-13, 05:46 PM   #15
Had a delivery while I was at Astle, nice box full of replacement bits for the saw and engine.
I went for 3 vee pulleys with a slightly larger one on the engine to make up for the 1000rpm running speed compared to the 1500rpm of the old A1.
New set of bearings for the saw as they are buggered so now I need some time to sort it all out.
Next thing will be wheels as its a pain having to keep moving it with a sack truck.
Old 26-06-13, 07:02 PM   #16
Ready for action then Rob, no trees will be safe now!:crazy:
Old 26-06-13, 07:04 PM   #17
Yep. Soon be fitting them, then get the Danarm out, provided I can find a mug to hold the other end!!
Old 26-06-13, 07:14 PM   #18
Volunteer's form an orderly queue!
Old 26-06-13, 07:52 PM   #19
Somehow Pete I reckon I'm going to have to bribe someone with beer, food and money.....
Old 26-06-13, 08:38 PM   #20
And perhaps the offer of prosthetic limbs if things don't go quite according to plan!
