Old 13-09-17, 09:07 PM   #1
Default "Alpha" Petter-Light
Flicking through a 1936 copy of "The Electrical Engineer", I spotted an advert for a Petter Light set in the adds.
The set is listed as an "Alpha Petter Light"- what does the Alpha refer to, the smallest model perhaps? Not a term I have seen applied to these units before.
Nice price too, if only!
IMGA0913 by Phillip Sheppard, on Flickr
Old 13-09-17, 10:22 PM   #2
K_N_S_JENNINGS
K_N_S_JENNINGS's Avatar
Yep, the smallest ones were called alpha.
Simon
K_N_S_JENNINGS is offline   Reply With Quote
Old 13-09-17, 10:39 PM   #3
Thanks, not something I'd come across.
Old 13-09-17, 11:16 PM   #4
Neither have I, not to mention it making little sense.
Alpha is usually the leader of the pack.
Old 13-09-17, 11:28 PM   #5
K_N_S_JENNINGS
Suppose in a way it is the leader as in the first in the range?
Couple of pics of catalogue pages with the Alpha set.
Simon
Old 14-09-17, 09:20 AM   #6
Did it get them higher up alphabetical listings of plant - like the ubiquitous "Acme"?
Old 14-09-17, 01:08 PM   #7
sidecrank
Alpha = greek letter A .
sidecrank is offline   Reply With Quote
Old 14-09-17, 02:35 PM   #8
keith-pu8
keith-pu8's Avatar
I was thumbing though a mag the other day, 1940, ads for a Lister portable compressor and a Purer aqua water purification setup run on a Jap engine.
keith-pu8 is offline   Reply With Quote
Old 15-09-17, 08:11 AM   #9
Patrick Knight
Default Alpha-Petter
Hi Phill,
David Edgington in his book on the Petter M type engine says that the Alpha-Petter lighting plant was introduced in 1924 and was a slightly improved version of the 1922 set. The engine was a regular 1.5hp hopper -cooled with belt drive to the dynamo. Both items being mounted on a common base with ALPHA-PETTER case in.
The switchboard was a modified version of the regular switchboard and incorporated an automatic cut-in and cut-out, a shunt regulator and amp meter. Petter Limited claimed to have improved the storage battery which was of an enclosed type with sealed glass jars.
Patrick Knight
Patrick Knight is offline   Reply With Quote
